RME Device Packages for 3945 ISR Router.
carl.donaldson
I am looking to see if I need a specific device package for Cisco 3945 routers.
At the moment we are running LMS 3.1 with RME 4.2.0
Can you advise what packages and versions I will need for these device models.
These servers need manual updates applied as no access to cisco.com auto updating.
Thanks in advance
Joe Clarke
Yes, there is an Rtr3900 package available via Common Services > Software Center > Device Update.  Check the boxes next to Common Services and RME, then download and install all available packages.  That will properly add 3900 support.
