What Service stopped the BARS in IPCCX 5.02
Answered Question
May 11th, 2010
  • " /> Participante em Destaque,
    Prêmio"Escolha dos membros": novembro de 2014
Hi Guys,
I will simulate a one fail in the generate backup ipccx and I did the procedure to generate the alarm. The first test I didn´t resulting, I change the username but the backup was generated without problem. I would like know what the service in IPCCX 5.02 is responsible to start the backup. I am to do this tests, because, my Customer would like alarm when occur any problem in backup IPCCX.
Wilson Santana
Correct Answer by Anthony Holloway about 6 years 10 months ago
That's surprising to me that changing the credentials to a known invalid value, still resulted in a successful backup.
If all you are trying to do, is create a failure so you can see what the alarm looks like, just use the alarm definitions to check out what's possible.
http:///appadmin/alarm?request_type=alarm.find&catalog=MCVD-BAR_CLIENT&alarmname=
I think what you are asking is roughly equivalent to stopping the CRS Engine, because you want an alarm generated, correct?
Well, with bars, there is no service that is always running.  It's a process that is kicked off at a scheduled time.
Overall Rating: 5 (1 ratings)
Anthony Holloway Tue, 05/11/2010 - 13:58
  • Purple, 4500 points or more
There is not a service, rather a utility.  It's kicked off by a scheduled task.
wilsonsant Tue, 05/11/2010 - 14:07
Hi Anthony,
I am sorry, but, If I need stopped the BARS It is necessary only not scheduler nothing date? Is this?
Wilson
Correct Answer
Anthony Holloway Tue, 05/11/2010 - 14:53
wilsonsant Tue, 05/11/2010 - 14:56
Hi Anthony,
My Customer would like receive alerts when the backup presenter any problem. I did already the configuration, but, I would like simulate this situation to validate my configuration. In my first try I change the username, but, the backup was did without problem.
Wilson
Correct Answer
Anthony Holloway Tue, 05/11/2010 - 15:35
