decommisioning Unity 5
Answered Question
May 11th, 2010
Is there something i need to do to decommision Unity 5? I upgraded to Unity 7 so I turned Unity 5 off, everything has been running fine so I would like to get rid of it, anything I need to do?
Correct Answer by David Hailey about 7 years 2 months ago
No, upgrade steps in general - sounds like you bought new servers.  So, I'll assume you upgraded from 5x to 7x with new servers since you asked about just "turning off" Unity 5.  So, if this was in the same AD - you'd need to use GSM to move user accounts from one server to another.  If you've done all that and all works well (which I believe you said it was fine), then you can just turn off the 5x server and be done with it.
Hailey
Overall Rating: 5 (1 ratings)
David Hailey Tue, 05/11/2010 - 06:28
  • Purple, 4500 points or more
If you're done with all upgrade steps (GSM, etc), then you just need to shut down the servers.  Optionally, you can delete the server-specific accounts created (EAdmin, etc) but not really necessary and they are disabled accounts in the first place.
Hailey
Please rate helpful posts!
Correct Answer
David Hailey Tue, 05/11/2010 - 08:32
Hailey
