Auto attendant and voice mailbox
Answered Question
May 11th, 2010
Hi Experts
I am new to voice, we have in our environment
CISCO router 1800 series
CUE v 7.0
a small implementation at one location
ext 11 is autoattendant the user wants to have a voice mailbox attached to this auto attendant
first is this possible to have a voice mailbox assoictaed with the auto attendant and if yes how we can do that
if not what are other options
Asif
Correct Answer by Brandon Buffin about 6 years 9 months ago
I'm assuming you have a menu in the AA script  (Press 1 for sales, 2 for customer service, etc.)? If so, you could, for example, have the caller press 3 for voicemail. This would trigger a call redirect step that would forward the caller to 1111 (or another number of your choosing). In my example, 1000 is the number that sends callers to voicemail. Your VM DN is likely different.
Brandon
Overall Rating: 5 (1 ratings)
Brandon Buffin Tue, 05/11/2010 - 05:42
Asif,
     Here's one way to do this. This assumes that your voicemail DN is 1000.
1. Create an ephone DN and call-forward all to voicemail
ephone-dn 1
number 1111
call-forward all 1000
2. Create a mailbox in CUE with the extension 1111
3. Create a Call Redirect step in your auto attendant script that transfers the call to 1111.
Hope this helps.
Brandon
akhanwaterloo Tue, 05/11/2010 - 05:50
Hi Brandon
well user wants to keep the auto attendant at be active at all times.
so what i understood from your response is
create a new extension 1111
and in the auto attndant prompt script put an option to press 1111 to redirect call to voice message.
so am i correct ?
i did not understand why to call forward all to 1000
Asif
Correct Answer
Brandon Buffin Tue, 05/11/2010 - 05:54
Brandon
