blackberry registeration with CME
Juan Carlos Ari... Wed, 09/01/2010 - 11:46
Paolo, just to confirm, you can't register a blackberry even on a CUCM??  Cause there is no SIP client!!??
Paolo Bevilacqua Fri, 09/03/2010 - 05:59
I have heard that there is SIP solution for BB now. I don't remember the name, but I will update this as I get it again.
Otherwise use Cisco CUMA to reach the integration level with it documented.
Juan Carlos Ari... Fri, 09/03/2010 - 06:58
Thanks Paolo, I understand that CUMA is the better choice of integration, but I'll like to try a third party SIP software to do this, please update if you remember the name.
auppal Thu, 09/09/2010 - 10:46
Buy any sip voip client on BB and create an EZVPN config on the CME. If you need assistance with that download the cisco configuration Profesional it has a very good template that will help you configure it.
THanks
Ankur
paveltoleon Sat, 09/11/2010 - 13:22
It seems BlackBerry launched complete product - the BlackBerry® Mobile Voice System that can be integrated with CME:
http://na.blackberry.com/eng/services/business/blackberry_mvs/
Here is Configuration Guide:
http://docs.blackberry.com/en/admin/deliverables/20062/BlackBerry_Mobile_Voice_System-Configuration_Guide--1079341-0901073810-001-5.0.1-US.pdf
What I have noticed from document is that "the BlackBerry® Mobile Voice System integrates your organization's PBX phone system with the BlackBerry® Enterprise Server to extend desk phone features to BlackBerry devices". In other words you will need BlackBerry® Enterprise Server working as well for the system to function.
So I guess to install all it if you have only couple of BlackBerry phones is senseless.
I'm curious if it would be possible to use without BlackBerry® Enterprise Server having just simple client on the phone like Nokia Call Connect, for instance with Nokia E-series phones.
