GE 1 Port on NME-16ES-1G-P a 17th switchport?
May 11th, 2010
I have a Cisco 2811 router with Advanced Enterprise Services, NME-16ES-1G-P, WIC-1T Serial Card, and (2x) FE ports.
I have 17 devices (servers, VoIP phone, etc.) that need to be on the same VLAN.  Essentially, I just want to use the NME-16ES-1G-P module like a switch for these devices, and then interface to the WAN via the FE0/0 port.  Is the GE 1 Port on the NME-16ES-1G-P configurable to be simply a 17th switchport to accomplish what I desire, or can it only be used for more advanced features like stacking or WAN interface?
I have to use the 2811, and I'd rather not install a switch in addition to the router.  Thanks!
http://www.cisco.com/en/US/docs/routers/access/interfaces/nm/hardware/installation/guide/conneths.html#wp1124285
Also, if I could add an HWIC-D-9ESW card, can it be configured to be nothing more an extension of 9 more switchports on the same VLAN as the NME-16ES-1G-P ports, or must they be separate VLANs?
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/esw_cfg.html#wp1027129
Sorry if these are easy questions, I'm just getting acclimated with Cisco modules in routers like a 2811.  Thanks!
Overall Rating: 5 (2 ratings)
vvasisth Tue, 05/11/2010 - 06:17
  • Silver, 250 points or more
i am not sure i understood you correctly however, when we talk about HWIC module its completly layer 2 module which can be used only to add more switchports to the router. But when we talk about NME module its a complete switch in itself. It based on 3750 architecture and can do everything a 3750 can do that includes routing and layer 3 ports as well. Moreover you can stack it with 3750 to be used as a stack of switch.
If by gig 1 you mean the internal link b/w 2800 and NME module then it has to be either a layer 3 link or it could be a trunk link so that you have communication b.w 2800 and NME module.
Please let me know if you have any other questions.
regards,
Varun
Leo Laohoo Tue, 05/11/2010 - 19:37
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
NME-16ES-1G has 16 10/100BaseTx and 1 10/100/1000BaseTx ports.  You can connect anything you want into them.
