Cut-through proxy, looking for a logout function.
Jennifer Halim Tue, 05/11/2010 - 06:21
Unfortunately there is no logout function from the user's perspective.
You can configure absolute or idle timeout for the uauth/cut through proxy function: timeout uauth hh:mm:ss [absolute | inactivity]:
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/t.html#wp1540870
You can however log user out from the PIX itself: clear uauth :
http://www.cisco.com/en/US/docs/security/asa/asa82/command/reference/c3.html#wp2169624
Hope that helps.
Jennifer Halim Tue, 05/11/2010 - 14:51
Yes, PIX and ASA is sharing the same code from version 7.0 onwards, with ASA supporting more features. However, feature that is both supported in PIX and ASA has the same implementation.
