How do i configure ASA to default configuration?
Answered Question
May 11th, 2010
hey guys,
What is the command to convert my ASA 5520 back to default configuration? I am doing a redesign and I am copying and pasting my current config. Can anyone help with the command?
Correct Answer by hobbe about 6 years 9 months ago
enable
conf t (configure terminal)
configure factory-default
thats it..
good luck
Overall Rating: 5 (1 ratings)
Correct Answer
hobbe Tue, 05/11/2010 - 06:58
enable
thats it..
good luck
