William Bell Tue, 05/11/2010 - 07:57
Depends on what you need to recover.
For OS and the Cluster Security Password:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/7_1_2/cucos/iptpch2.html#wp1044244
For the web administrative user:
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp113347
HTH.
Bill
Please remember to rate helpful posts using the scale below.
les.combs Tue, 05/11/2010 - 08:11
Thanks very much, hopefully the customer still has the DVD.
William Bell Tue, 05/11/2010 - 08:15
Your welcome! Actually, I believe you can use any DVD/CD as long as it is a data CD/DVD (don't use a music cd).  You may want to double check the text to be sure.  All it is doing is check to see if you have physical access to the system.  The assumption being if you have physical access then you must be trusted to a certain extent?
Please remember to rate helpful posts using the scale/stars below.
Thanks and regards,
Bill
Related Content
