vpn on TOSHIBA SATELLITE PRO T130-15G
May 11th, 2010
I want to buy a new pc : toshiba satellite pro t130-15g and i would like to know if i can use on it my vpn version 4.0.1 .
I already use this version of cisco vpn on my old pc (a toshiba satellite u200 with windows xp).
Can someone help me end tell me if the new pc (toshiba satellite pro t130-15g) with windows 7 (64 bit) can support the vpn cisco version 4.0.1?
Thanks in advance for your reply
Federico Coto F... Tue, 05/11/2010 - 09:21
  • Green, 3000 points or more
If you're running windows 64-bit, the recommended option is to use the Anyconnect VPN SSL client.
If you want to use an IPsec client, you can download a special release for 64-bit:
The IPsec VPN client was not intended for 64-bit, but you can use this release (works on vista and windows xp)
vpnclient-winx64-msi-5.0.07.0290-k9.exe
Federico.
BCIAerospace Wed, 05/12/2010 - 01:00
thnk u so much..but i didn't understant : can I use this release
also for windows 7 professional that is already  installed on thoshiba satellite t 130-15g(and not only for vista  and windows xp)?
thank u for your prompt reply
