Writing Boolean variables to MS SQL Server
May 11th, 2010
I cannot figure this out.
In the script I'm working on, a boolean variable can be dynamic either True / False ,etc
I cannot get the syntex correct to write this variable to a "binary" datatype column in SQL Server.
Column name in database is Binary
I have tried :
UPDATE da-database
SET [email protected]
WHERE First=400
da-databaseTEST
SET Binary=&bStatus
WHERE First=400
da-databaseTEST
SET Binary=bStatus
WHERE First=400
But if I use
da-databaseTEST
SET Binary=1
WHERE First=400
It sets the field to true i.e, Works correctly.  Just get get it going with a variable.
kkelly Wed, 05/12/2010 - 11:24
it is UCCX and
I'm having issues writing to a database doing any variable substitution.
I gave up on the boolean and decided to use just strings but hitting Null.Pointer Exceptions even though (IMHO) things are correct.
Is there a particular varaible type that I should defining in SQL that works "best" with the java beans and IPCC?
Gergely Szabo Thu, 05/13/2010 - 07:01
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
Hi, can you post the SQL query (the one generating Nullpointers)? G.
