UCCX 5.0 HA implementation
May 11th, 2010
I will be adding an HA server to an existing UCCX 5.0 implementation. I have a few questions:
1) Do I need a totally new Cisco OS 2003 CD or can I reuse the software? (Any issues with Windows Security Identifier?)
2) Do I need to purchase the Cisco SQL 2000 CD? Would that be something that wouldn't have come in a UCCX order with the OS and UCCX software?
Order of Operation:
1) Install SQL 2000 on existing production server
2) Install OS and UCCX on new Server
3) Install SQL 2000 on HA server
Am I missing anything?
Thanks in advance for any help.
Overall Rating: 5 (5 ratings)
William Bell Tue, 05/11/2010 - 11:03
  • Purple, 4500 points or more
Well, the OS 2003 CD is a OEM license for Windows software.  The platform install must recognize the Cisco MCS hardware to load (though it will load in vmware and will require activation if you do this).  If you are asking does the Cisco OS 2003 DVD give you a license that you can load on any server you please, then the answer is: no.  If you are asking if you can use the same media and it will work.  I believe so, just have the licenses in case you are audited.
When you order the UCCX server with High Availability, it comes with MS SQL 2000.  Part of the reason that HA has an additional cost is due to the fact that Cisco needs to pay Microsoft for the SQL server license.  So, yes you need to make a purchase.  NOTE:  You also need a special license from Cisco to enable High Availability (HA).  You can upgrade your existing license and work with your Cisco or partner account team to get the right software/pricing.
bimckenz wrote:
Order of Operation:
At a high level, that sounds correct.  See the installation guide and this link to fine tune your process:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} http://tools.cisco.com/search/display?url=http%3A%2F%2Fwww.cisco.com%2Fen%2FUS%2Fdocs%2Fvoice_ip_comm%2Fcust_contact%2Fcontact_center%2Fcrs%2Fexpress_7_0%2Fresources_card%2Fguide%2Fuccx70sqlrescrd.pdf
HTH.
Bill
Please remember to rate helpful posts.
bimckenz Tue, 05/11/2010 - 11:20
Bill, Thank you for the detailed and quick response. I appreciate it.
1) I was just asking if you could reuse the same media. Thanks for the reply.
2) The server wasn't ordered originally with High Availability. This server was set up as a single node UCCX server and has been in production for a couple of years. They had another MCS server that was just lying around. Now, they want to make this a UCCX HA environment using the unused server. They just purchased the HA license but don't have OS or UCCX software that was ordered specifically for the unused server.
So it sounds like they will need to order the Cisco SQL Server 2000 software.
What do I need to do to convert the single node server that is already in production to be the first node in the new HA setup?
Bill
Anthony Holloway Tue, 05/11/2010 - 14:15
You can technically use the same media, as the product key used for MCS servers is the same no matter what disc you are using.  Like Bill said, audit can bite you in the butt.
You don't have to do anything to the first node to have it accept the second node.  i.e., switch the deployment type from single node to first node.
bimckenz Wed, 05/12/2010 - 06:48
I found an unopened Windows 2003 OS for UCCX. Do the current and HA server have to be the exact same Windows 2003 version?
One version is OS 2003.1.5a and the one I can use would be OS 2003.1.2.
Just wondering if there would be any issues with doing that.
Bill
Anthony Holloway Wed, 05/12/2010 - 15:48
Are you using documentation to help you do this install?
Aaron Harrison Thu, 05/13/2010 - 00:32
  • Community Spotlight Award,
    Member's Choice, May 2015
You would want the same software on both server, yes.
The important part is that you have the same version of the application, but the OS upgrade also includes patches for SQL. If you apply different levels of OS patching, you'll probably end up with slight differences in the SQL version, and it won't add the secondary node to the cluster.
Aaron
Please rate helpful posts...
