Dialplan / Translation Problem with incoming calls on uc540
May 11th, 2010
I have had my first UC500 Project finished. All is working fine. Only incoming calls from the same City will be displayed with the Costumers number.
Will say a call comes in like 6912341234 it will be shown as 0695675670 (wich is the destination base number) on the phone. All other translation working, in and outgoing.
I can't find the error and any help will be appreciated.
Best Regards
@lex
here is my conf:
trunk group ALL_BRI
hunt-scheme longest-idle
translation-profile outgoing PROFILE_ALL_BRI
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g711alaw
voice register global
voice hunt-group 1 parallel
final 399
list 201,202
timeout 16
pilot 503
voice translation-rule 1
rule 1 /200/ /0/
rule 2 /^.*\(..\)/ /\1/
voice translation-rule 2
rule 1 /^97266950/ /200/
rule 2 /^9726695/ /2/
voice translation-rule 4
rule 15 // //
voice translation-rule 20
rule 1 /^\(.*\)/ /\1/ type subscriber subscriber
rule 2 /^\(.*\)/ /0\1/ type national national
rule 3 /^\(.*\)/ /00\1/ type international international
voice translation-profile BRI-in
translate calling 20
translate called 2
voice translation-profile BRI-out
translate calling 1
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 4
voice translation-profile PROFILE_ALL_BRI
translate calling 1
voice translation-profile VM_Profile
translate called 2000
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice-card 0
interface BRI0/1/0
no ip address
isdn switch-type basic-net3
isdn timer T310 60000
isdn overlap-receiving T302 2000
isdn point-to-point-setup
isdn incoming-voice voice
isdn send-alerting
isdn sending-complete
isdn static-tei 0
trunk-group ALL_BRI 64
interface BRI0/1/1
no ip address
isdn send-alerting
isdn static-tei 0
voice-port 0/0/0
cptone DE
station-id number 229
caller-id enable
voice-port 0/0/1
timeouts ringing infinity
voice-port 0/0/2
voice-port 0/0/3
voice-port 0/1/0
compand-type a-law
cptone DE
voice-port 0/1/1
compand-type a-law
cptone DE
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
description ** CCA Analog Fax **
destination-pattern 229
port 0/0/0
no sip-register
dial-peer voice 2 pots
service stcapp
port 0/0/1
dial-peer voice 3 pots
service stcapp
port 0/0/2
dial-peer voice 4 pots
service stcapp
port 0/0/3
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 52 pots
trunkgroup ALL_BRI
corlist outgoing call-international
description **CCA*Germany*International Calls**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 4
destination-pattern 000T
forward-digits all
no sip-register
dial-peer voice 53 pots
trunkgroup ALL_BRI
corlist outgoing call-toll-free
description **CCA*Germany*International Freecall**
preference 4
destination-pattern 000800T
forward-digits all
no sip-register
dial-peer voice 54 pots
trunkgroup ALL_BRI
corlist outgoing call-national
description **CCA*Germany*Innovtive Numbering**
preference 4
destination-pattern 0012.........T
forward-digits all
no sip-register
dial-peer voice 55 pots
trunkgroup ALL_BRI
corlist outgoing call-national-plus
description **CCA*Germany*Mobile**
preference 4
destination-pattern 001[567].........
forward-digits all
no sip-register
dial-peer voice 56 pots
trunkgroup ALL_BRI
description **CCA*Germany*Trunked Radio**
preference 4
destination-pattern 00167.......
forward-digits all
no sip-register
dial-peer voice 57 pots
trunkgroup ALL_BRI
description **CCA*Germany*Shared Cost Services**
preference 4
destination-pattern 00180[1-5]......
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_BRI
description **CCA*Germany*VPN**
preference 4
destination-pattern 00181....T
forward-digits all
no sip-register
dial-peer voice 59 pots
trunkgroup ALL_BRI
description **CCA*Germany*User Groups**
preference 4
destination-pattern 0018[2-9]........
forward-digits all
no sip-register
dial-peer voice 60 pots
trunkgroup ALL_BRI
description **CCA*Germany*National NGN**
preference 4
destination-pattern 00322[12][1-9]......
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup ALL_BRI
description **CCA*Germany*Personal Numbering**
preference 4
destination-pattern 0070[01]........
forward-digits all
no sip-register
dial-peer voice 62 pots
trunkgroup ALL_BRI
description **CCA*Germany*Freephone**
preference 4
destination-pattern 0080[01].......
forward-digits all
no sip-register
dial-peer voice 64 pots
trunkgroup ALL_BRI
description **CCA*Germany*Directory Enquiries**
preference 4
destination-pattern 01180..
forward-digits all
no sip-register
dial-peer voice 65 pots
trunkgroup ALL_BRI
preference 4
destination-pattern 0118..
forward-digits all
no sip-register
dial-peer voice 66 pots
trunkgroup ALL_BRI
corlist outgoing call-emergency
description **CCA*Germany*Police (110) and Emergency (112)**
preference 4
destination-pattern 011[02]
forward-digits all
no sip-register
dial-peer voice 67 pots
trunkgroup ALL_BRI
preference 4
destination-pattern 11[02]
forward-digits all
no sip-register
dial-peer voice 68 pots
trunkgroup ALL_BRI
description **CCA*Germany*Geographic Numbers**
preference 4
destination-pattern 0[2-9]....T
forward-digits all
no sip-register
dial-peer voice 3002 pots
description All-Bri
translation-profile incoming BRI-in
translation-profile outgoing BRI-out
destination-pattern .T
incoming called-number 9726695.T
direct-inward-dial
port 0/1/1
dial-peer voice 3000 pots
description All-Bri
direct-inward-dial
port 0/1/0
dial-peer voice 51 pots
description **CCA*Germany*Premium**
shutdown
destination-pattern 00900.......
forward-digits all
no sip-register
dial-peer voice 63 pots
shutdown
forward-digits all
no sip-register
no dial-peer outbound status-check pots
telephony-service
video
fxo hook-flash
max-ephones 40
max-dn 300
ip source-address 10.1.1.1 port 2000
max-redirect 20
auto assign 10 to 43
auto assign 5 to 8 type anl
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service phone SPA525-Encryption-key detim_wlan_2512
service phone SPA525-wifi-on yes
service phone SPA525-protocol SPCP
service phone SPA525-auto-detect-sccp yes
service phone SPA525-http-write yes
service phone SPA525-SSID detim-voice
service phone SPA525-readonly no
service phone SPA525-Encryption-type WPA2_PSK
service dnis overlay
service dnis dir-lookup
timeouts interdigit 2
system message detim IT Consulting GmbH
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
cnf-file location flash:
user-locale DE
network-locale DE
load 521G-524G cp524g-8-1-17
load 525G spa525g-7-4-3
load 501G spa5x5-7-4-3
load 502G spa5x5-7-4-3
load 504G spa5x5-7-4-3
load 508G spa5x5-7-4-3
load 509G spa5x5-7-4-3
time-zone 23
time-format 24
date-format dd-mm-yy
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$e/z4$rFuDCJwrvHrCZRVJpXXug/
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 0.T
transfer-pattern 6... blind
secondary-dialtone 0
fac standard
create cnf-files version-stamp 7960 May 04 2010 15:31:41
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys idle  Redial Newcall Mobility Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Mobility Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  10  dual-line
number 200 no-reg primary
label 0
description 200
name 0
call-forward busy 399
call-forward noan 399 timeout 20
huntstop channel
ephone-dn  11  dual-line
number 202 no-reg primary
label 202
description Analog A
name Analog A
call-forward noan 399 timeout 10
ephone-dn  12  dual-line
number 203 no-reg primary
label 203
description Analog B
name Analog B
ephone-dn  13  dual-line
number 204 no-reg primary
label 204
description Analog C
name Analog C
ephone-dn  14  dual-line
number 211 no-reg primary
label 211
description D Fahrendholz
name D Fahrendholz
call-forward all 061516283384
ephone-dn  15  dual-line
number 210 no-reg primary
label 210
description M U
name M Ue
mobility
call-forward noan 399 timeout 25
ephone-dn  16  dual-line
number 207 no-reg primary
label 207
description 207
name 207
ephone-dn  17  dual-line
number 208 no-reg primary
label 208
description EINS Test
name EINS Test
ephone-dn  18  dual-line
number 209 no-reg primary
label 209
description 209
name 209
ephone-dn  21  dual-line
number 212 no-reg primary
label 212
description Ke
name Kai
ephone-dn  22  dual-line
number 213 no-reg primary
label 213
description Hafid Razouk
name Hafid Razouk
ephone-dn  23  dual-line
number 214 no-reg primary
label 214
description Ma
name Moh
ephone-dn  24  dual-line
number 215 no-reg primary
label 215
description Abu
name Al
ephone-dn  25  dual-line
number 216 no-reg primary
label 216
description Konferenzraum A
name Konferenzraum A
ephone-dn  26  dual-line
number 217 no-reg primary
label 217
description Konferenzraum B
name Konferenzraum B
ephone-dn  27  dual-line
number 218 no-reg primary
label 218
description 218
name 218
ephone-dn  28  dual-line
number 219 no-reg primary
label 219
description 219
name 219
ephone-dn  29  dual-line
number 220 no-reg primary
label 220
description 220
name 220
ephone-dn  30  dual-line
number 221 no-reg primary
label 221
description 221
name 221
ephone-dn  31  dual-line
number 222 no-reg primary
label 222
description 222
name 222
ephone-dn  32  dual-line
number 223 no-reg primary
label 223
description 223
name 223
ephone-dn  33  dual-line
number 224 no-reg primary
label 224
description 224
name 224
ephone-dn  34  dual-line
number 225 no-reg primary
label 225
description 225
name 225
ephone-dn  35  dual-line
number 226 no-reg primary
label 226
description 226
name 226
ephone-dn  36  dual-line
number 227 no-reg primary
label 227
description 227
name 227
ephone-dn  37  dual-line
number 228 no-reg primary
label 228
description 228
name 228
ephone-dn  38  dual-line
number 229 no-reg primary
label 229
description Analog Fax
name Analog Fax
ephone-dn  39  dual-line
number 230 no-reg primary
label 230
description 230
name 230
ephone-dn  40  dual-line
number 231 no-reg primary
label 231
description 231
name 231
ephone-dn  41  dual-line
number 232 no-reg primary
label 232
description 232
name 232
ephone-dn  42  dual-line
number 233 no-reg primary
label 233
description 233
name 233
ephone-dn  43  dual-line
number 234 no-reg primary
label 234
description 234
name 234
ephone-dn  44  dual-line
number 235 no-reg primary
label 235
description 235
name 235
ephone-dn  45  dual-line
number 236 no-reg primary
label 236
description 236
name 236
ephone-dn  298
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  299
number A801... no-reg primary
mwi off
ephone-dn  300
number A800... no-reg primary
mwi on
Marcos Hernandez Wed, 05/12/2010 - 08:17
  • Blue, 1500 points or more
Can you please provide a "debug isdn q931" for sample problem call?
Marcos
Alexander Kluge-Wolf Wed, 05/12/2010 - 11:56
Hi Marcos,
thanks for looking into my problem...
Here are the logs: one with isdn q931 only, the other with isdn q931 and voip ccapi inout for more details.
@lex
debug isdn q931:
021098: May 12 07:25:29.308: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x23
    Bearer Capability i = 0x9090A3
        Standard = CCITT
        Transfer Capability = 3.1kHz Audio
        Transfer Mode = Circuit
        Transfer Rate = 64 kbit/s
    Channel ID i = 0x89
        Exclusive, B1
    Progress Ind i = 0x8183 - Origination address is non-ISDN
    Calling Party Number i = 0x2181, '6930855420'
        Plan:ISDN, Type:National
    Called Party Number i = 0xC1, '972669516'
        Plan:ISDN, Type:Subscriber(local)
021099: May 12 07:25:29.312: ISDN BR0/1/0 Q931: TX -> SETUP_ACK pd = 8  callref = 0xA3
    Channel ID i = 0x89
        Exclusive, B1
021100: May 12 07:25:31.320: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 20
021101: May 12 07:25:31.320: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0039 callID = 0x8039 switch = basic-net3 interface = User
021102: May 12 07:25:31.320: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xA3
021103: May 12 07:25:31.340: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x39
        Standard = CCITT
    Channel ID i = 0x82
        Preferred, B2
    Calling Party Number i = 0x2181, '20'
    Sending Complete
021104: May 12 07:25:31.924: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xB9
    Channel ID i = 0x8A
        Exclusive, B2
021105: May 12 07:25:32.504: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x53
    Sending Complete
        Standard = CCITT
    Channel ID i = 0x89
        Exclusive, B1
    Progress Ind i = 0x8083 - Origination address is non-ISDN
    Calling Party Number i = 0x2183, '6997266950'
021106: May 12 07:25:32.528: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xD3
    Channel ID i = 0x89
        Exclusive, B1
021107: May 12 07:25:32.552: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8  callref = 0xD3
    Progress Ind i = 0x8188 - In-band info or appropriate now available
021108: May 12 07:25:33.184: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0xB9
    Progress Ind i = 0x8288 - In-band info or appropriate now available
021109: May 12 07:25:33.192: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0xA3
021110: May 12 07:25:42.804: ISDN BR0/1/1 Q931: TX -> CONNECT pd = 8  callref = 0xD3
    Channel ID i = 0x89
        Exclusive, B1
021111: May 12 07:25:42.976: ISDN BR0/1/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x53
021112: May 12 07:25:42.980: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to 6997266950 N/A
021113: May 12 07:25:43.140: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8  callref = 0xB9
    Date/Time i = 0x0A050C0919
        Date (dd-mm-yr)   = 10-05-12
        Time (hr:mnt:sec) = 09:25:174
021114: May 12 07:25:43.144: %ISDN-6-CONNECT: Interface BRI0/1/0:2 is now connected to 972669516 N/A
021115: May 12 07:25:43.144: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x39
021116: May 12 07:25:43.172: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8  callref = 0xA3
    Channel ID i = 0x89
        Exclusive, B1
021117: May 12 07:25:43.196: ISDN BR0/1/0 Q931: RX <- FACILITY pd = 8  callref = 0xB9
    Facility i = 0x91A116020200A4020122300DA1053003020101820100830100
        Protocol Profile = Remote Operations Protocol
        0xA116020200A4020122300DA1053003020101820100830100
        Component = Invoke component
            Invoke Id = 164
            Operation = AOCDChargingUnit
021118: May 12 07:25:43.432: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x23
021119: May 12 07:25:43.432: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 6930855420 N/A
021120: May 12 07:25:43.556: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x23
    Cause i = 0x8590 - Normal call clearing
021121: May 12 07:25:43.568: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0xA3
021122: May 12 07:25:43.588: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x39
    Cause i = 0x8090 - Normal call clearing
021123: May 12 07:25:43.768: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x23
021124: May 12 07:25:43.856: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x53
021125: May 12 07:25:43.888: ISDN BR0/1/1 Q931: TX -> RELEASE pd = 8  callref = 0xD3
021126: May 12 07:25:44.032: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0xB9
    Facility i = 0x91A116020200A5020122300DA1053003020101820101830100
        0xA116020200A5020122300DA1053003020101820101830100
            Invoke Id = 165
021127: May 12 07:25:44.036: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x39
021128: May 12 07:25:44.048: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x53
debug isdn q931 and voip ccapi inout:
detim_GW#
019275: May 12 05:37:58.540: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for destaddr=217.92.4.131, prot=50, spi=0xFFD9FFD0(4292476880), srcaddr=213.61.185.186
019276: May 12 05:38:08.296: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x58
        Standard = CCITT
    Channel ID i = 0x89
        Exclusive, B1
    Called Party Number i = 0xC1, '97266951'
019277: May 12 05:38:08.300: ISDN BR0/1/1 Q931: TX -> SETUP_ACK pd = 8  callref = 0xD8
    Channel ID i = 0x89
        Exclusive, B1
019278: May 12 05:38:08.300: //-1/61289D2D8025/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=
   ----- ccCallInfo IE subfields -----
   cisco-ani=6930855420
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=97266951
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
019279: May 12 05:38:08.300: //-1/61289D2D8025/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x879C4E40, Call Info(
   Calling Number=6930855420,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=97266951(TON=Subscriber, NPI=ISDN),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE,
   Incoming Dial-peer=20038, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=ALL_BRI, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
019280: May 12 05:38:08.304: //-1/61289D2D8025/CCAPI/ccCheckClipClir:
   In: Calling Number=6930855420(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
019281: May 12 05:38:08.304: //-1/61289D2D8025/CCAPI/ccCheckClipClir:
   Out: Calling Number=6930855420(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
019282: May 12 05:38:08.304: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019283: May 12 05:38:08.304: :cc_get_feature_vsa malloc success
019284: May 12 05:38:08.304: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019285: May 12 05:38:08.304:  cc_get_feature_vsa count is 3
019286: May 12 05:38:08.304: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019287: May 12 05:38:08.304: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312114488,feature_id:455
019288: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6930855420(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=97266951(TON=Subscriber, NPI=ISDN))
019289: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/cc_process_call_setup_ind:
   Event=0x8794CBC0
019290: May 12 05:38:08.304: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 97266951
019291: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/ccCallSetContext:
   Context=0x8A0A06D8
019292: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 292 with tag 20038 to app "_ManagedAppProcess_Default"
019293: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/ccCallSetupAck:
   Call Id=292
019294: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/cc_api_set_transfer_info:
   Transfer Number=, Transfer Reason=0x0
019295: May 12 05:38:08.304: //292/61289D2D8025/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=TRUE, Tone=Dial Tone,
   Tone Direction=Network, Params=0x0, Call Id=292
019296: May 12 05:38:08.308: //292/61289D2D8025/CCAPI/ccSetDigitTimeouts:
   Initial Digit Timeout=-1000(ms), Inter Digit Timeout=-1000(ms)
019297: May 12 05:38:08.308: //292/61289D2D8025/CCAPI/ccSetDigitTimeouts:
   Call Entry(Inter Digit Timeout=10000(ms), Initial Digit Timeout=10000(ms))
019298: May 12 05:38:08.308: //292/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x124, digit_event=0x1, enable=TRUE, consume=FALSE)
019299: May 12 05:38:08.308: //292/61289D2D8025/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=292
019300: May 12 05:38:08.308: //292/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x879C4E40, callID=0x124, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
019301: May 12 05:38:08.308: //292/61289D2D8025/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x879C4E40, Call Id=292
019302: May 12 05:38:08.308: //292/61289D2D8025/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=15000(ms), Inter Digit Timeout=10000(ms))
019303: May 12 05:38:08.808: ISDN BR0/1/1 Q931: RX <- INFORMATION pd = 8  callref = 0x58
    Called Party Number i = 0xC1, '6'
019304: May 12 05:38:08.808: //292/61289D2D8025/CCAPI/cc_api_call_info:
   Info Digits=6, Info Complete=FALSE,
   Interface=0x879C4E40, Data Bitmask=0x0, Call Id=292
019305: May 12 05:38:10.808: //292/61289D2D8025/CCAPI/cc_api_call_info:
   Info Digits=, Info Complete=TRUE,
019306: May 12 05:38:10.808: //292/xxxxxxxxxxxx/CCAPI/ccCallReportDigits:
   (callID=0x124, digit_event=0x0, enable=FALSE, consume=FALSE)
019307: May 12 05:38:10.808: //292/61289D2D8025/CCAPI/ccCallReportDigits:
019308: May 12 05:38:10.808: //292/xxxxxxxxxxxx/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x879C4E40, callID=0x124, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
019309: May 12 05:38:10.808: //292/61289D2D8025/CCAPI/cc_api_call_report_digits_done:
019310: May 12 05:38:10.808: //292/61289D2D8025/CCAPI/cc_api_call_report_digits_done:
019311: May 12 05:38:10.808: //292/61289D2D8025/CCAPI/ccCallProceeding:
   Progress Indication=NULL(0)
019312: May 12 05:38:10.812: //292/61289D2D8025/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=3000, Params=0x8A096E28, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
019313: May 12 05:38:10.812: //292/61289D2D8025/CCAPI/ccCheckClipClir:
   In: Calling Number=20(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
019314: May 12 05:38:10.812: //292/61289D2D8025/CCAPI/ccCheckClipClir:
   Out: Calling Number=20(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed)
019315: May 12 05:38:10.812: //292/61289D2D8025/CCAPI/ccCallSetupRequest:
   Destination Pattern=.T, Called Number=972669516, Digit Strip=TRUE
019316: May 12 05:38:10.812: //292/61289D2D8025/CCAPI/ccCallSetupRequest:
   Calling Number=20(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=972669516(TON=Subscriber, NPI=ISDN),
   Redirect Number=, Display Info=
   Account Number=, Final Destination Flag=FALSE,
   Guid=61289D2D-5CBF-11DF-8025-68EFBD7FFA60, Outgoing Dial-peer=3000
019317: May 12 05:38:10.816: //292/61289D2D8025/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=20
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=1
   dest=972669516
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
019318: May 12 05:38:10.816: //292/61289D2D8025/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x879B5344, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=20,(Calling Name=)(TON=National, NPI=ISDN, Screening=User, Passed, Presentation=Allowed),
   Called Number=972669516(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=FALSE, Outgoing Dial-peer=3000, Call Count On=FALSE,
   Source Trkgrp Route Label=ALL_BRI, Target Trkgrp Route Label=, tg_label_flag=1, Application Call Id=)
019319: May 12 05:38:10.816: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019320: May 12 05:38:10.816: :cc_get_feature_vsa malloc success
019321: May 12 05:38:10.816: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019322: May 12 05:38:10.816:  cc_get_feature_vsa count is 4
019323: May 12 05:38:10.816: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019324: May 12 05:38:10.816: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312113368,feature_id:456
019325: May 12 05:38:10.816: //293/61289D2D8025/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
019326: May 12 05:38:10.816: //293/61289D2D8025/CCAPI/ccCallSetContext:
   Context=0x8A096DD8
019327: May 12 05:38:10.816: //292/61289D2D8025/CCAPI/ccSaveDialpeerTag:
019328: May 12 05:38:10.820: ISDN BR0/1/0 Q931: Applying typeplan for sw-type 0x1 is 0x2 0x1, Calling num 20
019329: May 12 05:38:10.820: ISDN BR0/1/0 Q931: Sending SETUP  callref = 0x0036 callID = 0x8036 switch = basic-net3 interface = User
019330: May 12 05:38:10.820: ISDN BR0/1/1 Q931: TX -> CALL_PROC pd = 8  callref = 0xD8
019331: May 12 05:38:10.820: ISDN BR0/1/0 Q931: TX -> SETUP pd = 8  callref = 0x36
        Standard = CCITT
    Channel ID i = 0x81
        Preferred, B1
    Sending Complete
019332: May 12 05:38:11.372: ISDN BR0/1/0 Q931: RX <- CALL_PROC pd = 8  callref = 0xB6
    Channel ID i = 0x89
        Exclusive, B1
019333: May 12 05:38:11.376: //293/61289D2D8025/CCAPI/cc_api_call_proceeding:
   Interface=0x879B5344, Progress Indication=NULL(0)
019334: May 12 05:38:11.924: ISDN BR0/1/0 Q931: RX <- SETUP pd = 8  callref = 0x7C
    Sending Complete
        Standard = CCITT
    Channel ID i = 0x8A
        Exclusive, B2
019335: May 12 05:38:11.932: //-1/6352CE748026/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=6997266950
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=972669516
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
019336: May 12 05:38:11.932: //-1/6352CE748026/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x879B5344, Call Info(
   Calling Number=6997266950,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=3002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
019337: May 12 05:38:11.932: //-1/6352CE748026/CCAPI/ccCheckClipClir:
   In: Calling Number=6997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
019338: May 12 05:38:11.932: //-1/6352CE748026/CCAPI/ccCheckClipClir:
   Out: Calling Number=6997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
019339: May 12 05:38:11.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019340: May 12 05:38:11.932: :cc_get_feature_vsa malloc success
019341: May 12 05:38:11.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019342: May 12 05:38:11.932:  cc_get_feature_vsa count is 5
019343: May 12 05:38:11.932: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019344: May 12 05:38:11.932: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312113816,feature_id:457
019345: May 12 05:38:11.932: //294/6352CE748026/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=6997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=972669516(TON=Subscriber, NPI=ISDN))
019346: May 12 05:38:11.936: //294/6352CE748026/CCAPI/cc_process_call_setup_ind:
   Event=0x8794CBC0
019347: May 12 05:38:11.936: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 972669516
019348: May 12 05:38:11.936: //294/6352CE748026/CCAPI/ccCallSetContext:
   Context=0x8A0A7998
019349: May 12 05:38:11.936: //294/6352CE748026/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 294 with tag 3002 to app "_ManagedAppProcess_Default"
019350: May 12 05:38:11.936: //294/6352CE748026/CCAPI/ccCallProceeding:
019351: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=20017, Params=0x8A09BAA8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
019352: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccCheckClipClir:
   In: Calling Number=06997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
019353: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccCheckClipClir:
   Out: Calling Number=06997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed)
019354: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Destination Pattern=216$, Called Number=216, Digit Strip=TRUE
019355: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Calling Number=06997266950(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=216(TON=Subscriber, NPI=ISDN),
   Account Number=, Final Destination Flag=TRUE,
   Guid=6352CE74-5CBF-11DF-8026-68EFBD7FFA60, Outgoing Dial-peer=20017
019356: May 12 05:38:11.940: //294/6352CE748026/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=06997266950
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=216
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
019357: May 12 05:38:11.940: //294/6352CE748026/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x88A6EC6C, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=06997266950,(Calling Name=)(TON=National, NPI=ISDN, Screening=Network, Presentation=Allowed),
   Called Number=216(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20017, Call Count On=FALSE,
019358: May 12 05:38:11.940: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019359: May 12 05:38:11.944: :cc_get_feature_vsa malloc success
019360: May 12 05:38:11.944: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019361: May 12 05:38:11.944:  cc_get_feature_vsa count is 6
019362: May 12 05:38:11.944: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019363: May 12 05:38:11.944: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312113592,feature_id:458
019364: May 12 05:38:11.944: //295/6352CE748026/CCAPI/ccIFCallSetupRequestPrivate:
019365: May 12 05:38:11.944: //295/6352CE748026/CCAPI/ccCallSetContext:
   Context=0x8A09BA58
019366: May 12 05:38:11.944: //294/6352CE748026/CCAPI/ccSaveDialpeerTag:
019367: May 12 05:38:11.944: //295/6352CE748026/CCAPI/cc_api_update_call_info:
   Interface=0x88A6EC6C, Call Id=0x127
019368: May 12 05:38:11.948: //295/6352CE748026/CCAPI/cc_api_call_proceeding:
   Interface=0x88A6EC6C, Progress Indication=NULL(0)
019369: May 12 05:38:11.952: //295/6352CE748026/CCAPI/cc_api_call_alert:
   Interface=0x88A6EC6C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
019370: May 12 05:38:11.952: //295/6352CE748026/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
019371: May 12 05:38:11.956: //294/6352CE748026/CCAPI/ccCallAlert:
019372: May 12 05:38:11.956: //294/6352CE748026/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
019373: May 12 05:38:11.956: //295/6352CE748026/CCAPI/ccCallFeature:
   Feature Type=25, Call Id=295
019374: May 12 05:38:11.964: ISDN BR0/1/0 Q931: TX -> CALL_PROC pd = 8  callref = 0xFC
    Channel ID i = 0x8A
        Exclusive, B2
019375: May 12 05:38:11.984: ISDN BR0/1/0 Q931: TX -> ALERTING pd = 8  callref = 0xFC
019376: May 12 05:38:12.644: ISDN BR0/1/0 Q931: RX <- ALERTING pd = 8  callref = 0xB6
019377: May 12 05:38:12.648: //293/61289D2D8025/CCAPI/cc_api_call_alert:
   Interface=0x879B5344, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
019378: May 12 05:38:12.648: //293/61289D2D8025/CCAPI/cc_api_call_alert:
019379: May 12 05:38:12.648: //292/61289D2D8025/CCAPI/ccCallAlert:
019380: May 12 05:38:12.648: //292/61289D2D8025/CCAPI/ccCallAlert:
019381: May 12 05:38:12.648: //292/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA40, callID1=0x124, callID2=0x125, tag=0x0)
019382: May 12 05:38:12.648: //292/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA40, callID1=0x124, gcid=61289D2D-5CBF11DF-802568EF-BD7FFA60, tag=0x0)
019383: May 12 05:38:12.648: //293/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA40, callID2=0x125, gcid=61289D2D-5CBF11DF-802568EF-BD7FFA60, tag=0x0)
019384: May 12 05:38:12.648: //292/61289D2D8025/CCAPI/ccConferenceCreate:
   Conference Id=0x8A04DA40, Call Id1=292, Call Id2=293, Tag=0x0
019385: May 12 05:38:12.648: //292/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x54, Source Interface=0x879C4E40, Source Call Id=292,
   Destination Call Id=293, Disposition=0x0, Tag=0xFFFFFFFF
019386: May 12 05:38:12.652: //293/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x54, Source Interface=0x879B5344, Source Call Id=293,
   Destination Call Id=292, Disposition=0x0, Tag=0xFFFFFFFF
019387: May 12 05:38:12.652: //292/61289D2D8025/CCAPI/cc_generic_bridge_done:
019388: May 12 05:38:12.652: //292/61289D2D8025/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x54, Destination Call Id=293)
019389: May 12 05:38:12.652: //293/61289D2D8025/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x54, Destination Call Id=292)
019390: May 12 05:38:12.652: //292/61289D2D8025/CCAPI/cc_api_caps_ind:
   Destination Interface=0x879B5344, Destination Call Id=293, Source Call Id=292,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x2,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
019391: May 12 05:38:12.652: //292/61289D2D8025/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
019392: May 12 05:38:12.652: //293/61289D2D8025/CCAPI/cc_api_caps_ind:
   Destination Interface=0x879C4E40, Destination Call Id=292, Source Call Id=293,
019393: May 12 05:38:12.652: //293/61289D2D8025/CCAPI/cc_api_caps_ind:
019394: May 12 05:38:12.652: //293/61289D2D8025/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=ON(0x2),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=5159)
019395: May 12 05:38:12.652: //292/61289D2D8025/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6999)
019396: May 12 05:38:12.656: //293/61289D2D8025/CCAPI/cc_api_voice_mode_event:
   Call Id=293
019397: May 12 05:38:12.656: //293/61289D2D8025/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x8A096DD8)
019398: May 12 05:38:12.656: //292/61289D2D8025/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x54, Call Id1=292, Call Id2=293
019399: May 12 05:38:12.660: ISDN BR0/1/1 Q931: TX -> ALERTING pd = 8  callref = 0xD8
019400: May 12 05:38:12.660: //292/61289D2D8025/CCAPI/cc_api_voice_mode_event:
   Call Id=292
019401: May 12 05:38:12.660: //292/61289D2D8025/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x8A0A06D8)
019402: May 12 05:38:21.952: //295/6352CE748026/CCAPI/cc_api_call_disconnected:
   Cause Value=19, Interface=0x88A6EC6C, Call Id=295
019403: May 12 05:38:21.952: //295/6352CE748026/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=19, Retry Count=0)
019404: May 12 05:38:21.952: //294/xxxxxxxxxxxx/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
019405: May 12 05:38:21.952: //295/6352CE748026/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
019406: May 12 05:38:21.952: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
   type=6 redirecting_number=216
019407: May 12 05:38:21.952: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectNumber:
   type=6  Original Called Number=216, Called Number=216, Calling Number=06997266950, Calling DN=-1 Calling Id=294,
   Redirect Number=399, Redirect Reason=2
019408: May 12 05:38:21.952: //-1/xxxxxxxxxxxx/CCAPI/ccUpdateRedirectingNumber:
019409: May 12 05:38:21.952: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019410: May 12 05:38:21.952: :cc_get_feature_vsa malloc success
019411: May 12 05:38:21.952: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019412: May 12 05:38:21.952:  cc_get_feature_vsa count is 7
019413: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019414: May 12 05:38:21.956: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312114040,feature_id:459
019415: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019416: May 12 05:38:21.956:  feature_vsa is 89D00E90,featname is 0
019417: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019418: May 12 05:38:21.956: :cc_get_feature_vsa malloc success
019419: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019420: May 12 05:38:21.956:  cc_get_feature_vsa count is 8
019421: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019422: May 12 05:38:21.956: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312114264,feature_id:460
019423: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019424: May 12 05:38:21.956: : Generating new featurevsa,inserting it
019425: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019426: May 12 05:38:21.956:  feature call forward featname is 3
019427: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019428: May 12 05:38:21.956:  feature_vsa is 89D00DB0,featname is 0
019429: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019430: May 12 05:38:21.956: :cc_get_feature_vsa malloc success
019431: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019432: May 12 05:38:21.956:  cc_get_feature_vsa count is 9
019433: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019434: May 12 05:38:21.956: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312114712,feature_id:461
019435: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019436: May 12 05:38:21.956: : Generating new featurevsa,inserting it
019437: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019438: May 12 05:38:21.956:  feature call forward featname is 3
019439: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019440: May 12 05:38:21.956: :cc_free_feature_vsa freeing 89D00F70
019441: May 12 05:38:21.956: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019442: May 12 05:38:21.956:  vsacount in free is 8
019443: May 12 05:38:21.956: //294/6352CE748026/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=294
019444: May 12 05:38:21.956: //295/6352CE748026/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=19)
019445: May 12 05:38:21.956: //295/6352CE748026/CCAPI/ccCallDisconnect:
   Cause Value=19, Call Entry(Responsed=TRUE, Cause Value=19)
019446: May 12 05:38:21.956: //295/6352CE748026/CCAPI/cc_api_get_transfer_info:
019447: May 12 05:38:21.968: //295/6352CE748026/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x88A6EC6C, Tag=0x0, Call Id=295,
   Call Entry(Disconnect Cause=19, Voice Class Cause Code=0, Retry Count=0)
019448: May 12 05:38:21.968: //295/6352CE748026/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
019449: May 12 05:38:21.968: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019450: May 12 05:38:21.968: :cc_free_feature_vsa freeing 89D01210
019451: May 12 05:38:21.968: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019452: May 12 05:38:21.968:  vsacount in free is 7
019453: May 12 05:38:21.968: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019454: May 12 05:38:21.968:  vsacount in free is 6
019455: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019456: May 12 05:38:21.972: :cc_get_feature_vsa malloc success
019457: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019458: May 12 05:38:21.972:  cc_get_feature_vsa count is 7
019459: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019460: May 12 05:38:21.972: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312113592,feature_id:462
019461: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019462: May 12 05:38:21.972:  feature call forward featname is 3
019463: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019464: May 12 05:38:21.972: :cc_free_feature_vsa freeing 89D00DB0
019465: May 12 05:38:21.972: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019466: May 12 05:38:21.972:  vsacount in free is 6
019467: May 12 05:38:21.972: //294/6352CE748026/CCAPI/ccGetTBCTCap:
   TGRM TBCT Enabled; TBCT Capability=0
019468: May 12 05:38:21.972: //294/6352CE748026/CCAPI/ccGetTBCTCap:
019469: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=2000, Params=0x8A09F408, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
019470: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccCheckClipClir:
019471: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccCheckClipClir:
019472: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Destination Pattern=399, Called Number=399, Digit Strip=FALSE
019473: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccCallSetupRequest:
   Called Number=399(TON=Subscriber, NPI=ISDN),
   Redirect Number=216, Display Info=
   Guid=69500285-5CBF-11DF-839C-E71537CC0FD4, Outgoing Dial-peer=2000
019474: May 12 05:38:21.976: //294/6352CE748026/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-anitype=2
   cisco-aniplan=1
   cisco-anipi=0
   cisco-anisi=3
   dest=399
   cisco-desttype=4
   cisco-destplan=1
   cisco-rdie=73
   cisco-rdn=216
   cisco-lastrdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=0
   cisco-rdnsi=0
   cisco-redirectreason=2   fwd_final_type =0
019475: May 12 05:38:21.976: //294/6352CE748026/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x86BA3D94, Interface Type=3, Destination=, Mode=0x0,
   Called Number=399(TON=Subscriber, NPI=ISDN), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=2000, Call Count On=FALSE,
019476: May 12 05:38:21.976: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019477: May 12 05:38:21.976: :cc_get_feature_vsa malloc success
019478: May 12 05:38:21.976: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019479: May 12 05:38:21.976:  cc_get_feature_vsa count is 7
019480: May 12 05:38:21.976: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019481: May 12 05:38:21.976: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312113592,feature_id:463
019482: May 12 05:38:21.980: //296/6352CE748026/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
019483: May 12 05:38:21.980: //296/6352CE748026/CCAPI/ccCallSetContext:
   Context=0x8A09F3B8
019484: May 12 05:38:21.980: //294/6352CE748026/CCAPI/ccSaveDialpeerTag:
019485: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019486: May 12 05:38:21.980:  feature call forward featname is 3
019487: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019488: May 12 05:38:21.980:  feature_vsa is 89D00DB0,featname is 0
019489: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019490: May 12 05:38:21.980: :cc_get_feature_vsa malloc success
019491: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019492: May 12 05:38:21.980:  cc_get_feature_vsa count is 8
019493: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
019494: May 12 05:38:21.980: :FEATURE_VSA attributes are: feature_name:0,feature_time:2312114712,feature_id:464
019495: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019496: May 12 05:38:21.980: : Generating new featurevsa,inserting it
019497: May 12 05:38:21.980: //-1/xxxxxxxxxxxx/CCAPI/cc_update_feature_vsa:
019498: May 12 05:38:21.980:  feature call forward featname is 3
019499: May 12 05:38:21.980: //296/6352CE748026/CCAPI/cc_api_call_proceeding:
   Interface=0x86BA3D94, Progress Indication=NULL(0)
019500: May 12 05:38:22.028: //296/6352CE748026/CCAPI/cc_api_call_alert:
   Interface=0x86BA3D94, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
019501: May 12 05:38:22.028: //296/6352CE748026/CCAPI/cc_api_call_alert:
019502: May 12 05:38:22.028: //294/6352CE748026/CCAPI/ccCallAlert:
019503: May 12 05:38:22.028: //294/6352CE748026/CCAPI/ccCallAlert:
019504: May 12 05:38:22.028: //294/6352CE748026/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
019505: May 12 05:38:22.052: //296/6352CE748026/CCAPI/cc_api_call_connected:
   Interface=0x86BA3D94, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
019506: May 12 05:38:22.052: //296/6352CE748026/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
019507: May 12 05:38:22.056: //294/6352CE748026/CCAPI/ccGenerateToneInfo:
019508: May 12 05:38:22.056: //294/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA88, callID1=0x126, callID2=0x128, tag=0x0)
019509: May 12 05:38:22.056: //294/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA88, callID1=0x126, gcid=6352CE74-5CBF11DF-802668EF-BD7FFA60, tag=0x0)
019510: May 12 05:38:22.056: //296/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x8A04DA88, callID2=0x128, gcid=6352CE74-5CBF11DF-802668EF-BD7FFA60, tag=0x0)
019511: May 12 05:38:22.056: //294/6352CE748026/CCAPI/ccConferenceCreate:
   Conference Id=0x8A04DA88, Call Id1=294, Call Id2=296, Tag=0x0
019512: May 12 05:38:22.056: //294/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x55, Source Interface=0x879B5344, Source Call Id=294,
   Destination Call Id=296, Disposition=0x0, Tag=0xFFFFFFFF
019513: May 12 05:38:22.056: //296/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
019514: May 12 05:38:22.056: cc_api_get_xcode_stream : 4546
019515: May 12 05:38:22.056: //296/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x55, Source Interface=0x86BA3D94, Source Call Id=296,
   Destination Call Id=294, Disposition=0x0, Tag=0x0
019516: May 12 05:38:22.056: //294/6352CE748026/CCAPI/cc_generic_bridge_done:
019517: May 12 05:38:22.056: //294/6352CE748026/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x55, Destination Call Id=296)
019518: May 12 05:38:22.056: //296/6352CE748026/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x55, Destination Call Id=294)
019519: May 12 05:38:22.060: //294/6352CE748026/CCAPI/cc_api_caps_ind:
   Destination Interface=0x86BA3D94, Destination Call Id=296, Source Call Id=294,
   Caps(Codec=0x1, Fax Rate=0x1, Fax Version:=0, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
019520: May 12 05:38:22.060: //294/6352CE748026/CCAPI/cc_api_caps_ind:
019521: May 12 05:38:22.060: //296/6352CE748026/CCAPI/cc_api_caps_ind:
   Destination Interface=0x879B5344, Destination Call Id=294, Source Call Id=296,
   Caps(Codec=0x1, Fax Rate=0x2, Fax Version:=0, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
019522: May 12 05:38:22.060: //296/6352CE748026/CCAPI/cc_api_caps_ind:
019523: May 12 05:38:22.060: //296/6352CE748026/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Fax Version:=0, Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=9099)
019524: May 12 05:38:22.060: //294/6352CE748026/CCAPI/cc_api_caps_ack:
019525: May 12 05:38:22.060: //294/6352CE748026/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
019526: May 12 05:38:22.060: //294/6352CE748026/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
019527: May 12 05:38:22.064: //294/6352CE748026/CCAPI/cc_api_voice_mode_event:
   Call Id=294
019528: May 12 05:38:22.064: //294/6352CE748026/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x8A0A7998)
019529: May 12 05:38:22.064: //294/6352CE748026/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x55, Call Id1=294, Call Id2=296
019530: May 12 05:38:22.068: ISDN BR0/1/0 Q931: TX -> CONNECT pd = 8  callref = 0xFC
    Channel ID i = 0x8A
        Exclusive, B2
019531: May 12 05:38:22.288: ISDN BR0/1/0 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x7C
019532: May 12 05:38:22.288: %ISDN-6-CONNECT: Interface BRI0/1/0:2 is now connected to 6997266950 N/A
019533: May 12 05:38:22.420: ISDN BR0/1/0 Q931: RX <- CONNECT pd = 8  callref = 0xB6
    Date/Time i = 0x0A050C0726
        Time (hr:mnt:sec) = 07:38:174
019534: May 12 05:38:22.424: %ISDN-6-CONNECT: Interface BRI0/1/0:1 is now connected to 972669516 N/A
019535: May 12 05:38:22.424: ISDN BR0/1/0 Q931: TX -> CONNECT_ACK pd = 8  callref = 0x36
019536: May 12 05:38:22.424: //293/61289D2D8025/CCAPI/cc_api_call_connected:
   Interface=0x879B5344, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
019537: May 12 05:38:22.424: //293/61289D2D8025/CCAPI/cc_api_call_connected:
019538: May 12 05:38:22.428: //292/61289D2D8025/CCAPI/ccCallConnect:
019539: May 12 05:38:22.428: //292/61289D2D8025/CCAPI/ccCallConnect:
019540: May 12 05:38:22.432: ISDN BR0/1/1 Q931: TX -> CONNECT pd = 8  callref = 0xD8
    Channel ID i = 0x89
        Exclusive, B1
019541: May 12 05:38:22.492: ISDN BR0/1/0 Q931: RX <- FACILITY pd = 8  callref = 0xB6
    Facility i = 0x91A115020102020122300DA1053003020101820100830100
        0xA115020102020122300DA1053003020101820100830100
            Invoke Id = 2
019542: May 12 05:38:22.588: ISDN BR0/1/1 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x58
019543: May 12 05:38:22.588: %ISDN-6-CONNECT: Interface BRI0/1/1:1 is now connected to 6930855420 N/A
019544: May 12 05:38:29.216: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x58
019545: May 12 05:38:29.216: %ISDN-6-DISCONNECT: Interface BRI0/1/1:1  disconnected from 6930855420 , call lasted 6 seconds
019546: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x879C4E40
019547: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/cc_api_call_disc_prog_ind:
   Event(Progress Indication=0x0), Call Entry(Responsed=TRUE)
019548: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/ccConferenceDestroy:
   Conference Id=0x54, Tag=0x0
019549: May 12 05:38:29.220: //292/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=293, Disposition=0x0, Tag=0x0
019550: May 12 05:38:29.220: //293/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=292, Disposition=0x0, Tag=0x0
019551: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/cc_generic_bridge_done:
019552: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
019553: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
019554: May 12 05:38:29.220: //292/61289D2D8025/CCAPI/cc_api_get_transfer_info:
019555: May 12 05:38:29.220: //293/61289D2D8025/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
019556: May 12 05:38:29.220: //293/61289D2D8025/CCAPI/ccCallDisconnect:
019557: May 12 05:38:29.220: //293/61289D2D8025/CCAPI/cc_api_get_transfer_info:
019558: May 12 05:38:29.224: //292/61289D2D8025/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
019559: May 12 05:38:29.224: //292/61289D2D8025/CCAPI/cc_api_call_disc_cause_update:
   Call Entry(Disconnect Cause=16)
019560: May 12 05:38:29.224: //292/61289D2D8025/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x879C4E40, Tag=0x0, Call Id=292,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
019561: May 12 05:38:29.228: //292/61289D2D8025/CCAPI/cc_api_call_disconnect_done:
019562: May 12 05:38:29.228: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019563: May 12 05:38:29.228: :cc_free_feature_vsa freeing 89D01130
019564: May 12 05:38:29.228: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019565: May 12 05:38:29.228:  vsacount in free is 7
019566: May 12 05:38:29.228: %ISDN-6-DISCONNECT: Interface BRI0/1/0:1  disconnected from 972669516 , call lasted 6 seconds
019567: May 12 05:38:29.228: ISDN BR0/1/1 Q931: TX -> RELEASE pd = 8  callref = 0xD8
019568: May 12 05:38:29.228: ISDN BR0/1/0 Q931: TX -> DISCONNECT pd = 8  callref = 0x36
019569: May 12 05:38:29.380: ISDN BR0/1/1 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x58
019570: May 12 05:38:29.676: ISDN BR0/1/0 Q931: RX <- DISCONNECT pd = 8  callref = 0x7C
019571: May 12 05:38:29.680: %ISDN-6-DISCONNECT: Interface BRI0/1/0:2  disconnected from 6997266950 , call lasted 7 seconds
019572: May 12 05:38:29.680: //294/6352CE748026/CCAPI/cc_api_call_disc_prog_ind:
   Cause Value=16, Progress Indication=INBAND(8), Interface=0x879B5344
019573: May 12 05:38:29.680: //294/6352CE748026/CCAPI/cc_api_call_disc_prog_ind:
019574: May 12 05:38:29.680: //294/6352CE748026/CCAPI/ccConferenceDestroy:
   Conference Id=0x55, Tag=0x0
019575: May 12 05:38:29.680: //294/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=296, Disposition=0x0, Tag=0x0
019576: May 12 05:38:29.680: //296/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
019577: May 12 05:38:29.680: //294/6352CE748026/CCAPI/cc_generic_bridge_done:
019578: May 12 05:38:29.684: //294/6352CE748026/CCAPI/ccCallDisconnect:
019579: May 12 05:38:29.684: //294/6352CE748026/CCAPI/ccCallDisconnect:
019580: May 12 05:38:29.684: //294/6352CE748026/CCAPI/cc_api_get_transfer_info:
019581: May 12 05:38:29.684: //296/6352CE748026/CCAPI/ccCallDisconnect:
019582: May 12 05:38:29.684: //296/6352CE748026/CCAPI/ccCallDisconnect:
019583: May 12 05:38:29.696: //296/6352CE748026/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x86BA3D94, Tag=0x0, Call Id=296,
019584: May 12 05:38:29.696: //296/6352CE748026/CCAPI/cc_api_call_disconnect_done:
019585: May 12 05:38:29.696: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019586: May 12 05:38:29.696: :cc_free_feature_vsa freeing 89D01210
019587: May 12 05:38:29.696: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019588: May 12 05:38:29.696:  vsacount in free is 6
019589: May 12 05:38:29.696: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019590: May 12 05:38:29.696:  vsacount in free is 5
019591: May 12 05:38:29.712: //294/6352CE748026/CCAPI/cc_api_call_disc_cause_update:
   Cause Value=16
019592: May 12 05:38:29.712: //294/6352CE748026/CCAPI/cc_api_call_disc_cause_update:
019593: May 12 05:38:29.712: //294/6352CE748026/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x879B5344, Tag=0x0, Call Id=294,
019594: May 12 05:38:29.712: //294/6352CE748026/CCAPI/cc_api_call_disconnect_done:
019595: May 12 05:38:29.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019596: May 12 05:38:29.712: :cc_free_feature_vsa freeing 89D01050
019597: May 12 05:38:29.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019598: May 12 05:38:29.712:  vsacount in free is 4
019599: May 12 05:38:29.712: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019600: May 12 05:38:29.712:  vsacount in free is 3
019601: May 12 05:38:29.716: ISDN BR0/1/0 Q931: RX <- RELEASE pd = 8  callref = 0xB6
    Facility i = 0x91A115020103020122300DA1053003020101820101830100
        0xA115020103020122300DA1053003020101820101830100
            Invoke Id = 3
019602: May 12 05:38:29.720: ISDN BR0/1/0 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x36
019603: May 12 05:38:29.720: //293/61289D2D8025/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x879B5344, Tag=0x0, Call Id=293,
019604: May 12 05:38:29.720: //293/61289D2D8025/CCAPI/cc_api_call_disconnect_done:
019605: May 12 05:38:29.720: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019606: May 12 05:38:29.720: :cc_free_feature_vsa freeing 89D00CD0
019607: May 12 05:38:29.720: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
019608: May 12 05:38:29.720:  vsacount in free is 2
019609: May 12 05:38:29.748: ISDN BR0/1/0 Q931: TX -> RELEASE pd = 8  callref = 0xFC
019610: May 12 05:38:29.936: ISDN BR0/1/0 Q931: RX <- RELEASE_COMP pd = 8  callref = 0x7C
Marcos Hernandez Sun, 05/16/2010 - 07:00
Please do this and try again:
  no translate calling 20
Marcos
Alexander Kluge-Wolf Mon, 05/17/2010 - 01:02
Hi Marcos,
tried but no luck.
I've done some further testings. Incomming call numbers seems to be translated with voice translation-rule 1, regardless what calling translation-rule statement I'm using.
Even we have the secondary-dialtone 0 statement in telephony-service, which will be ignored, meens you have to dial out without using the 0.
May you can provide a default config example, which should work with German isdn BRI inclusive the dial-peers and translation pattern.
Many thanks
@lex
Marcos Hernandez Tue, 05/18/2010 - 09:19
If I understood your initial description, you meant the caller ID (not the called number) was always the same for inbound calls (that is, calls into your IP phones, not made from IP phones). Is this the case? If so, the translation rule invoked by your dial peers 3002 and 3000 is rule 20. Please explain.
Marcos
Alexander Kluge-Wolf Tue, 05/18/2010 - 10:35
yes I mean incomming numbers.
In the meantime I solved the problem. I saw in the debug on all incoming calls starting with a 6 doing a call forward. Then it does some funny things and came back on the second BRI...(with the callerid number 97266950)
looking with "debug voip translation" and "debug voip ccapi inout" I saw it uses a hidden dial-peer (20038) and stood before my 3002 and 3000 dial-peer. Finally it came from this:
ephone-dn  298
and the translation-pattern 6... blind in the telphony-service.
After deleting this (nobody needs this here) the problem is solved. All calls coming in correctly now.
Thanks for your help.
