05-11-2010 11:50 AM
Is there anyway to perform a redirect on the ACE 4710 so that it will redirect a request sent to the domain mydomain.com be redirected to www.mydomain.com, this is so that an installed SSL certificate will match.
Solved! Go to Solution.
05-12-2010 07:16 AM
Then simply configure a redirect.
rserver redirect HTTP-REDIRECT
webhost-redirection https://www.mydomain.com%p
serverfarm redirect SF_REDIRECT
rserver HTTP-REDIRECT
inservice
Gilles.
05-12-2010 01:27 AM
The problem is that you will see the domain name only after decrypting the traffic.
So, the redirect, even if it can be done on the ACE, is uselss.
The browser will complain before receiving the redirect.
You can get an ssl certificate which contains multiple domain...something like *.domain.com.
Like this the browser will not complain.
This is called Wildcard SSL Certificates
You could also remove your dns entry for domain.com...this will force users to type the full name to get the ip address.
Gilles.
05-12-2010 05:31 AM
Thank you for your response, but the redirect would occur before any encyption.. for example today this is what happens
someone goes to
and the ACE redirects the connection to
What I want is for someone to go to
http://mydomain.com (without the www) and for it to redirect to
http://www.mydomain.com which will inturn redirect to https://www.mydomain.com
or it can just redirect to https://www.mydomain.com
So the encryption will not occur until it is redirected to teh correct websit
05-12-2010 07:16 AM
inservice
Gilles.
05-12-2010 08:00 AM
Thanks!,.. am I correct in thinking in the example below the %p is what is going to insert the full URP into the users browser?
inservice
