cuvc 5100 not booting
May 11th, 2010
hi,
i have just received from cisco demo depot cuvc 5100 which is not booting at all. the reset LED is red.
it hangs after 1% saying can't file a file (don't remember the exact name).
however keeping pressed RESET button for about 15 seconds moves me to some emergency mode and asks for LOGIN.
none admin,cisco or administrator username works.
does anyone have an idea what can be the username and password in that mode?
is there any chance to fix the cuvc without tac help?
best
aleksander
a.klessa Wed, 05/12/2010 - 04:30
i have found out that the username is 'root', but have no idea about a password.
this is what i see while booting cuvc
"U-Boot 1.3.4-rc1 (Sep 14 2009 - 15:04:47)
DBG Mode:
        operational + application
Boot failures counter: 0
Pause
reading uImage-0.1.18
2640906 bytes read
WARNING: adjusting available memory to 30000000
Starting filesystem from COMPACT FLASH
Checking filesystem image
ext2fs_check_if_mount: No such file or directory while determining whether /dev/loop0 is mounted.
/dev/loop0: 1168/15040 files (1.0% non-contiguous), 49410/60000 blocks
chenzzha Tue, 04/12/2011 - 03:19
hey,
Just wondering has this problem been solved? I am having the exact same issue with 5115-hd.
Chen
