Sw 4507R-E_Configuration - Instalation
Answered Question
May 11th, 2010
Hey Guys, in this opportunity, i need some help with this Switch. Does anyone has a quick manual for configuration e installation of this switch. Also i would like a graphics, or some images of this switch for knowing. Any link or doc that you recommend will help me.
I have to change varios sw 3750, and replace them with this switchcore. Any tips to do this, would be wonderfull.
I really appreciate your comments,
Correct Answer by Ganesh Hariharan about 6 years 10 months ago
Check out the below links on 4500 series switches :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/module/guide/01overvw.html
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/hardware/installation/guide/78-14409-08/03instal.html
http://www-europe.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/37sg/configuration/guides/pwr_envr.html
Hope to help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Tue, 05/11/2010 - 22:51
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hope to help !!
Ganesh.H
Related Content
