Unity Connection DRS stucks on Messages backup
Unity Connection 7.1, try to run the Disaster Recovery System for the CUC backup. Whenever I checked the option of "CONNECTION_MESSAGE_UNITYMBDB1", the backup will stuck in the same amount size such as 1,046,336KB for the message option. The backup status stays at the same percentage, and the backup file size is not increasing anymore.
If I uncheck this message backup option, the DRS works fine.
Can someone help me to point out where I should look for the problem?
JJ
David Hailey Tue, 05/11/2010 - 14:47
  • Purple, 4500 points or more
If you are backing up a cluster, I have seen this issue when you try to backup everything on the Publisher.
Do the following:
Create a backup folder for the Pub.
Create a separate backup folder for the Sub.
Backup all components EXCEPT messages on the Publisher to it's dedicated SFTP location.
Backup all components INCLUDING messages on the Subscriber to it's dedicated SFTP location.
Messages may fail on the Pub but should succeed on the Sub and yes, it takes a long time for message store to be backed up...so just let it run on the the first pass in this config.
Hailey
PLEASE RATE HELPFUL POSTS!
Bradford Magnani Tue, 05/11/2010 - 14:50
  • Cisco Employee,
Hi JJ,
There is also a known issue with the 1GB cap if you're using FreeFTPd.  The fix is to use something other than that server.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/drs_administration/guide/7xcucdrsag.html#wp42127
TAC has also written some instructions on how to use CoreFTP which has also been used in the past:
https://supportforums.cisco.com/docs/DOC-8142
Hope that helps,
Brad
David Hailey Tue, 05/11/2010 - 14:58
If that's your issue, I would recommend CopSSH...but I have seen your
issue independent of the sftp/ftp app file size limitation. However,
it's worth looking at that angle as well to see if the client is your
problem.
Sent from my iPhone
On May 11, 2010, at 5:50 PM, bmagnani
