Router simulating frame relay
smuhle91870
All,
I'm trying to create a full mesh network, but i keep getting the message of "Can't use same dlci on overlapping circuits"
I create the following from int s1/1 and on the second command I get the above message.
frame-relay route 102 int s1/0 101
frame-relay route 102 int s1/2 100
Can this be done or are my parameters wrong?
SM
bgandhi
Hi Steven,
This is not allowed. You need to map separate DLCI for each interface. You can use 102 for 1 interface but other has to be different, you may use 103.
Bhavesh
Calin C.
Level 5
Level 5
Here is an example:
! very important
frame-relay switching
interface Serial5/0:1
description TO_R2
no ip address
encapsulation frame-relay
frame-relay intf-type dce
frame-relay route 205 interface Serial5/1:2 502
frame-relay route 207 interface Serial6/0 702
frame-relay route 209 interface Serial6/1 902
As it was specified in the previous post one dlci / route.
Good luck!
That's what I'm finally figuring out.
Thanks a lot, to both responses.
