DMVPN Spoke failover
May 11th, 2010
All,
I am trying to implement a spoke failover into a DMVPN setup and it is taking an unacceptable 10 minutes. I am currently using a Cisco 2821 with an AIM VPN card as the hub router and Cisco 831s as the spoke routers.
Instead of using two ISP connections, I'm trying to get this working with a Peplink Balance WAN failover. Some of my end sites are way off in the boonies and will be using a wireless USB card as a backup ISP connection - something the Peplink supports. So far the Peplink is working the way it should: the main connection will failover to the secondary connection; the primary will take back over once it re-establishes itself.
The problem I'm having is with the DMVPN reconverging. Here's what I've tried and what I've noticed:
After the Peplink switches to a different provider, the spoke command, "show crypto session", shows that the IPsec tunnel will not relinquish to the new "Active" ISAKMP tunnel. These are on two different ports.
Interface: Tunnel1
Session status: DOWN
Peer: 24.1xx.1x.1xx port 500
  IPSEC FLOW: permit 47 host 192.168.2.2 host 24.124.17.129
        Active SAs: 0, origin: crypto map
Interface: Tunnel1
Session status: UP-IDLE
Peer: 24.124.17.129 port 4500
  IKE SA: local 192.168.2.2/4500 remote 24.1xx.1x.1xx/4500 Active
  IKE SA: local 192.168.2.2/4500 remote 24.1xx.1x.1xx/4500 Inactive
This problem clears up after 10 minutes. This seems to correspond with the NHRP configuration. The expiration of an "ip nhrp detail" is also 10 minutes.This results in the following on the spoke:
Interface: Tunnel1
Session status: UP-ACTIVE
Peer: 24.1xx.1x.1xx port 4500
  IPSEC FLOW: permit 47 host 192.168.2.2 host 24.1xx.1x.1xx
        Active SAs: 2, origin: crypto map
I've tried the following modifications without any luck:
I changed the "ip nhrp registration no-unique"
I changed the "ip nhrp holdtime 15"
Right now we do not have an elegant solution for two diverse, non 3g / cellular, ISP connections or else I would upgrade to the 1841s and setup two tunnels to the hub.
I've been really impressed with the DMVPN technology, so I'm hoping there's I can design the functionality that I'm looking for. Any help that you can offer is greatly appreciated!
Thanks!
-Mike
jayhawk11 Mon, 06/14/2010 - 19:24
All,
I was able to figure out the previous issue. I had to wait to get a duplicate environment setup before testing a very simple change - go figure.
The line to add to each router is:
crypto isakmp keepalive 10 periodic
This enables dead peer detection on both sides of the link. This decreased the downtime from 10 minutes to 30 seconds with the Peplink Balance 30 product.
If continually run
show ip nhrp detail
you'll see the ISAKMP session clear after 20-25 seconds. Within another 5 seconds or so you'll see the session startup again.
Hope this helps!
-Mike
