Nat for vpn
May 11th, 2010
Hi Everyone,
I having trouble configuring asa5520 using asdm 6.0.I need to nat  the ips below those belong to the public ip pool of 95.170.208.0/27 to 172.18.8.0/24
but as you see the interfaces below theres no interface with 172.18.8.0 network. What do you think I should do next ?
- 95.170.208.6  <->172.18.8.0/24
- 95.170.208.7  <->172.18.8.0/24
- 95.170.208.8  <->172.18.8.0/24
- 95.170.208.9  <->172.18.8.0/24
- 95.170.208.10 <->172.18.8.0/24
- 95.170.208.11 <->172.18.8.0/24
GigabitEthernet0/0          Backup                   192.168.100.254
GigabitEthernet0/1          Inside                      192.168.50.1
GigabitEthernet0/2          Internet-Backup      192.168.60.1
GigabitEthernet0/3          Wan-Direct             95.170.208.3
Management0/0              Manage                   192.168.1.1
spremkumar Wed, 05/12/2010 - 05:53
  • Red, 2250 points or more
When u select the NAT feature using ASDM dont you see an option to add network object ? You can make use of that option to create 172.18.8.0/24 and select to create the NAT rule.
But do make sure that you have proper route/acess permissions enabled to reach 172.18.8.0/24.
regds
Related Content
