How to check the utilization in router.
May 12th, 2010
Hi Dude.
In my office One of my router is conneced to Service Provider MPLS Router. My MPLS link in highly utilized. I want to check which ip address in utilizing the same. can any one help me.
Router Model : 2811
ohassairi Wed, 05/12/2010 - 01:05
you need to activate netflow feature
configure terminal
interface FastEthernet 0/1
ip route-cache flow
wait some time then
sho ip flow top-talkers
u can also use one GUI to collect and display flows stat such as net flow server (example ManageEngine_NetFlowAnalyzer.exe)
in this case you need to add these cmds:
ip flow-export destination 9996
ip flow-export source FastEthernet 0/1
ip flow-export version 5
ip flow-cache timeout active 1
ip flow-cache timeout inactive 15
snmp-server ifindex persist
Giuseppe Larosa Wed, 05/12/2010 - 04:58
Hello Tamilvanan,
netflow is technically better
but a simpler way is to use ip accounting:
int wan
ip acccounting output-packets
you can see stats with
sh ip accounting
this can be used to find out a PC using too much resources of performing peer-to-peer
Hope to help
