HSRP Implement with 3No.s Core Switch
Hi All,
I'm having 4 no.s 3750 as Distribution switching connecting as per standard Cisco Layer Architechture to Core1 & Core2, HSRP is running over there. Both Core Switch are 4506. Now we want a DR site for my DC outside ( within 10KM), and it will simply extending my LAN through Ethernet Over Fiber Channel. I want othe FO connectivity from all Distribution switch to a 3rd Core ( Core_3) switch 4506.
Please let me know if it is possible to have 3 switch pointing towards single gateway ( standby ) IP, as normal we do the with 2nos. Core switch. I'm not sure it can be done with 3no.s of switch also.
If Core_1 & Core_2 both will go down then Core_3 will come in the picture...is it also require any link to be conneced from Core_1 & Core_2 to Core_3 ?
Please look into the PPT....you can understand my existing setup...
Jon Marshall Wed, 05/12/2010 - 02:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
[email protected]
Hi All,
HSRP is not limited to 2 switches. So yes you can run HSRP between 3 switches if that is what you want to do. As long as there is L2 adjacency between all the core switches you will be fine.
Jon
Jon Marshall Tue, 05/18/2010 - 02:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
Please send me a sample HSRP config for a single VLAN for Core_1, 2 & 3
core 1
int vlan 10
ip address 192.168.5.2 255.255.255.0
standby 10 ip 192.168.5.1
standby 10 authentication
standby 10 preempt
standby 10 priority 110
core 2
int vlan 10
ip address 192.168.5.3 255.255.255.0
standby 10 priority 100
core 3
int vlan 10
ip address 192.168.5.4 255.255.255.0
standby 10 priority 90
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please rate all helpful posts.
Jon Marshall Tue, 05/18/2010 - 06:37
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
[email protected]
Hi Jon,
Please confirm me if I need to make a physical connection to Core_3 from Core_2, as in generally we do a direct connection ( may be a etherchannel ) in between Core_1 & Core_2.
Or I have to make a tringle connection in between Core_1, Core_2 & Core_3.
Each switch needs to be L2 adjacent to the other switches so
core1 -> L2 -> core2 -> L2 -> core 3  would be fine.
Jon
