route injection - non redistribution
Answered Question
May 12th, 2010
I am tring  to inject a default route in rip & eigrp without redistrubtion.
two of my routers R3 & R4 must use the default route.
I am succesfull when using a conditon route ( ie: acl+route map -only when network 1.0.0.0 is in R2 route table
but when I try  a eigrp summary + .default-information originate without the condition, it doesnt work
If possible can you tell me what I am missing or doing wrong.
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Pdriver,
the behaviour you see should be correct: RIP cannot generate a default route only because a default route is received in another routing protocol (EIGRP)
when you check for presence of EIGRP prefix  1/8  in IP routing table, RIP generates a default route.
otherwise you would need a static default route in IP routing table
http://www.cisco.com/en/US/docs/ios/iproute_rip/command/reference/irr_rip.html#wp1011008
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 05/12/2010 - 05:08
Hello Pdriver,
Hope to help
Giuseppe
