Help troubleshooting VPN on 877
May 12th, 2010
I'm trying to establish a site-to-site VPN connection but can't get traffic to pass through.
Please see cry show command output
U-PoS-877-01#show crypto ipsec sa
interface: Dialer1
    Crypto map tag: IPSEC_VPN, local addr 194.105.178.182
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.10.200.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.10.10.0/255.255.255.0/0/0)
   current_peer 194.105.164.41 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 194.105.178.182, remote crypto endpt.: 194.105.164.41
     path mtu 1500, ip mtu 1500, ip mtu idb Dialer1
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
   remote ident (addr/mask/prot/port): (10.10.11.0/255.255.255.0/0/0)
    #send errors 208, #recv errors 0
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
interface: Virtual-Access2
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
U-PoS-877-01#show crypto isakmp sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
194.105.164.41  194.105.178.182 QM_IDLE           2023 ACTIVE
IPv6 Crypto ISAKMP SA
Any help and advice would be greatly appreciated.
spremkumar Wed, 05/12/2010 - 04:29
  • Red, 2250 points or more
Hi tracey
what kinda traffic you are referring here ? is you ping/trace results normal ?
Have you tried tracing the remote end ips once the tunnel is up? do a trace and check where your trace is getting stuck, that may will help you to nail the problem.
regds
Jennifer Halim Wed, 05/12/2010 - 05:31
  • Cisco Employee,
Phase 1 is up, however, Phase 2 is not up yet as there is no inbound and outbound SAs.
If you can share the config from the other end too that would help. Or/ run "debug crypto ipsec" to see what it's failing on.
Venture101 Wed, 05/12/2010 - 07:17
Hi Halijenn,
Thanks for getting back to me.  It's appreciated.  The remote end is configured by a third party.  They are saying it's my config.
See attached for remote end configuration and crypto isakamp debug!
Cheers,
TC
Related Content
