Deny handhelds by MAC address??
Answered Question
May 12th, 2010
We have a couple of WLAN's here at our school.
One for handhelds only (hidden SSID PDA) with WPA2, another for all guests with Web authentication.(SSID Hotspot)
Now some of the handhelds are connecting by themselves to the Hotspot wireless network, but their apps won't work correct through the hotspot network.
We want to block the handhelds on the Hotspot WLAN i.e by MAC address.
How can we do that ??
Can't seem to find it in the manual..
Hans
Correct Answer by Leo Laohoo about 6 years 10 months ago
Nuts!  I didn't see that you are using LWAP.  My deepest apologies for wasting your time.
MAC Filters with Wireless LAN Controllers (WLCs) Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008084f13b.shtml
Overall Rating: 5 (1 ratings)
sciencecare Fri, 05/14/2010 - 10:13
Not sure which AP you are running but I accomplish this by creating a filter for each SSID one that forwards packets for the MAC address of allowed devices on the internal network and one that blocks packets on the free wi-fi.  I then apply that at the radio level so they can 'connect' to the other but it will not allow an IP to be pulled, so even if they try to switch to by pass our webfilter they cannot, yet visiting clients (we run events with lots of visitors) can connect to the wifi and surf freely.  Works good but I cannot give more specific direction since you didn't mention which device your using.
hvellekoop Mon, 05/17/2010 - 01:14
The device we use is the /* Style Definitions */ table.MsoNormalTable {mso-style-name:Standaardtabel; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";} Cisco Aironet AIR-AP1242AG-E-K9
AP's are configured through the Wireless Lan Controller.
Maybe this helps to be more specific?
Thanks for your assistence, much appreciated :-)
Leo Laohoo Sun, 05/16/2010 - 02:39
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Hans,
What SSIDs are the PDAs configured to associate?  Maybe the PDAs have both SSID configured and "Hotspot" SSID is set to connect automatically?
Please don't forget useful posts.  Thanks.
hvellekoop Mon, 05/17/2010 - 01:17
The Hotspot WLAN is discovered automatically, and sometimes the PDA connects to it.
Maybe cause the PDA WLAN is a hidden SSID ?
Leo Laohoo Mon, 05/17/2010 - 01:20
  • Hall of Fame,
    2017 LAN, Wireless
So why not put a password at the "Hotspot" SSID?  Even a simple one.  I've never heard of an application to automatically connect to an SSID without asking.
hvellekoop Mon, 05/17/2010 - 01:25
The Hotspot WLAN is secured with a web password, connecting is possible without password, but when you want to access the Internet, a username/password is required.
Leo Laohoo Mon, 05/17/2010 - 01:34
  • Hall of Fame,
    2017 LAN, Wireless
HTML into the AP.
Go to Services -> Filters -> MAC Address Filters tab.
Please don't forget to rate useful posts.  Thanks.
hvellekoop Mon, 05/17/2010 - 01:40
Yes, I've seen that Tab, but little explanation with it.. that's why I'm here..
I know form other AP I can filter on MAC, but that is to allow the specified MAC's to use the AP.
What I want is create a filter on the Hotspot SSID and deny all handhelds to connect to it.
Would that be possible with this filter?
(BTW, super .. your fast replies!! )
Leo Laohoo Mon, 05/17/2010 - 01:50
  • Hall of Fame,
    2017 LAN, Wireless
I hope you know how to use CLI ...
Access Point ACL Filter Configuration Example
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008058ed26.shtml
hvellekoop Mon, 05/17/2010 - 02:03
CLI is not the problem.
I guess you refer to this in the html file:
Create a MAC address ACL 700.
This ACL does not allow the client 0040.96a5.b5d4 to associate with             the AP.
access-list 700 deny 0040.96a5.b5d4 0000.0000.0000
But how to set the deny only on the SSID Hotspot WLAN?
Leo Laohoo Mon, 05/17/2010 - 02:26
  • Hall of Fame,
    2017 LAN, Wireless
How many radios does your AP have?  If 2 then configure Hotspot SSID to one radio and Handheld SSID to another radio.
Is this viable for you?
hvellekoop Mon, 05/17/2010 - 02:32
Not sure what radios is..
We have four SSID's on the WLC
Is that what radios is ?
Leo Laohoo Mon, 05/17/2010 - 02:33
  • Hall of Fame,
    2017 LAN, Wireless
Can you tell me what is the exact model number of your AP?  In CLI, can you post the output of the command "sh ip interface brief"?
hvellekoop Mon, 05/17/2010 - 03:47
Hi Leolaohoo,
Device is Cisco Aironet AIR-AP1242AG-E-K9
CLI output from the two concerning interfaces :
Interface Name................................... PDA
MAC Address...................................... 00:1a:6d:dd:85:
IP Address....................................... 172.22.1.2
IP Netmask....................................... 255.255.0.0
IP Gateway....................................... 172.22.1.1
VLAN............................................. 11
Quarantine-vlan.................................. 0
Active Physical Port............................. LAG (29)
Primary Physical Port............................ LAG (29)
Backup Physical Port............................. Unconfigured
Primary DHCP Server.............................. 172.21.1.11
Secondary DHCP Server............................ Unconfigured
DHCP Option 82................................... Disabled
ACL.............................................. Unconfigured
AP Manager....................................... No
Guest Interface.................................. No
Hotspot:
Interface Name................................... hotspot
MAC Address...................................... 00:1a:6d:dd:85:c7
IP Address....................................... 10.14.2.2
IP Netmask....................................... 255.255.254.0
IP Gateway....................................... 10.14.2.1
VLAN............................................. 14
Primary DHCP Server.............................. 172.31.1.108
Correct Answer
Leo Laohoo Mon, 05/17/2010 - 19:17
  • Hall of Fame,
    2017 LAN, Wireless
hvellekoop Tue, 05/18/2010 - 01:16
No problem m8 ..
You helped me very well, I'll look in to the file and try some things, looks like this is what I was looking for.
So thanks for time and support !
Cheers
Leo Laohoo Tue, 05/18/2010 - 01:24
  • Hall of Fame,
    2017 LAN, Wireless
If this addresses your issue, can you mark this thread as "Answered"?  Thanks Hans.
Leo Laohoo Tue, 05/18/2010 - 02:07
  • Hall of Fame,
    2017 LAN, Wireless
Thanks Hans.
Related Content
Trending Topics - Security & Network
