05-12-2010 06:36 AM - edited 03-06-2019 11:03 AM
I have a simple setup that consists of Router A (model 1800) and 2 switches (model 2950).
Port 1 of switch A is connected on port 2 of Router A and Port 1 of switch B is connected on port 3
of Router A. Also, port 49 of switch A is connected on port 49 of switch B.
I want to add a third switch but unfortunately I don't have the finance for a high end switch. I'm thinking
of adding a low end switch (ex: linksys). One link to switch A and another link to switch B for redundancy purpose.
I know the low end switch is not STP enabled, but can this type of setup create any loop issues ??
Solved! Go to Solution.
05-12-2010 07:08 AM
You would have an inherent loop in your setup when you connect A to B switch and then hang the dumb switch between them . As long as spanning tree is running on the 2950 it should take care of the loop and block one of the uplinks from the dumb switch I believe .Been a little while maybe someone can chime in whether the 2950's will talk spanning tree thru that dumb switch , brain cramp on this side . :-) Make sure you do not have portfast turned on for the ports going to that dumb switch . In that setup though if someone connects say 2 ports together by accident on the dumb switch it will likely take down that portion of the network with no spanning tree protection on that dumb switch.
05-12-2010 07:08 AM
05-12-2010 07:21 AM
Hi Glen,
Thanks for your quick reply,
I should be good to go. I'll make sure I have portfast disabled on switch A & B (uplink ports only).
Tony
05-12-2010 08:12 AM
Tony,
Check the LinkSys switch you are getting as some of them you can enable STP.
Glen, 5+ on the helpful information.
Mike
