Client unable to get DHCP IP from 871W
Answered Question
May 12th, 2010
I am playing around with an 871W router and have setup a local dhcp pool:
ip dhcp pool LAN_DHCP
     import all
     network 10.10.10.0 255.255.255.0
     default-router 10.10.10.1
The laptop connected to it isn't able to receive an IP.
Here is what I am seeing in the logs:
*Feb 28 21:19:16.963 CST: DHCPD: Sending notification of DISCOVER:
*Feb 28 21:19:16.963 CST:   DHCPD: htype 1 chaddr 001d.0937.a90d
*Feb 28 21:19:16.963 CST:   DHCPD: remote id 020a00000a190001f1000000
*Feb 28 21:19:16.963 CST:   DHCPD: circuit id 00000000
*Feb 28 21:19:16.963 CST: DHCPD: DHCPDISCOVER received from client 0100.1d09.37a9.0d on interface BVI1.
*Feb 28 21:19:16.963 CST: DHCPD: Seeing if there is an internally specified pool class:
*Feb 28 21:19:16.963 CST: DHCPD: Allocate an address without class information (10.10.10.0)
*Feb 28 21:19:16.963 CST: DHCPD: subnet [10.10.10.1,10.10.10.254] in address pool LAN_DHCP is empty.
*Feb 28 21:19:16.963 CST: DHCPD: Sending notification of ASSIGNMENT FAILURE:
*Feb 28 21:19:16.963 CST: DHCPD: Sending notification of ASSIGNMENT_FAILURE:
*Feb 28 21:19:16.963 CST:  DHCPD: due to: POOL EXHAUSTED
There is only my laptop connected to it and it's not connected to the Internet.
Any assistance would be appreciated!
Lily
Correct Answer by Jerry Ye about 7 years 2 weeks ago
Change your config to the following and try again
ip dhcp excluded-address 10.10.10.1 10.10.10.X
ip dhcp smart-relay
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Wed, 05/12/2010 - 08:09
  • Cisco Employee,
ip dhcp smart-relay
jerry
Mehdi Talei Tue, 09/10/2013 - 04:56
Adding the line fixes the issue, but why that happens at all!
There should be a bug somewhere that there are plenty of IP addresses available and the router is not able to attribute any! I can't find the bug on Cisco website though!
