05-12-2010 08:33 AM - edited 03-10-2019 05:07 PM
Just learning AAA and I'm struggling with one thing. I've got a RADIUS server set up and switches/routers authenticate to it. Everything's working fine.
As a safety measure I've got a local account set up as well, just in case both RADIUS servers are down.
I was able to configure them to log on users directly to privileged mode, which is quite convinient. However when I log on using the local account I'm in the privileged mode as well.
Is there a way to configure a switch/router to log on users who authenticated through RADIUS server directly to enable mode, but if a user logs on using a local account it will be in exec mode and will have to enter a password to access privileged mode?
Here's my configuration:
aaa new-model
aaa authentication login default group radius local
aaa authentication enable default group radius enable
aaa authorization exec default group radius local
enable secret 5 <...>
username testlocal privilege 15 password 7 <...>ip radius source-interface Vlan150
radius-server host 192.168.10.2 auth-port 1812 acct-port 1813 key 7 <...>
radius-server host 192.168.17.2 auth-port 1812 acct-port 1813 key 7 <...>
radius-server retransmit 3
Solved! Go to Solution.
05-12-2010 09:27 AM
Change:
to read:
username testlocal password 7 <...>
05-12-2010 09:27 AM
Change:
to read:
05-13-2010 02:22 AM
Hi Javier,
Thank you for the reply. I can't believe it was so easy to fix!
However in order to allow a local user to access 'enable mode' I had to remove this line as well:
as there was no way I could authenticate. The switch was using '$ena15$' as a username to authenticate on RADIUS server.
There was the same problem if I logged on using my Active Directory account, entered 'disable' command and then tried to go back to privileged mode.
I figured that I rather authenticate to enable mode locally.
Anyway it's all sorted now. Thank you again.
05-13-2010 04:48 AM
That is the expected behavior with RADIUS.
With TACACS+, it will send the actual username.
