a question about application inspection configuration?
May 12th, 2010
dear experts, hello
when i configure an application inspection for some protocols or applications i may use its class map  like ( ftp-map MY-FTP-CLASS) then define
some parameters in its prompts...
another way i may say ( policy-map type inspect ftp MY-FTP-CLASS)
so what is the difference between them, thanks alot for your help
labib
Jennifer Halim Thu, 05/13/2010 - 03:24
  • Cisco Employee,
If you uses ftp-map, then the inspection is specific to just the ftp protocol. Same goes for http, where it is matching on http application specific, as different application has different application format, ie: ftp and http are 2 different protocols that have specific application feature.
With the normal class-map, it is normally just matching on source/destination ip address and/or protocol and port number.
Hope that helps.
