How to broadcast 2 SSIDs on the same radio interface on the default VLAN?
May 12th, 2010
Hi guys,
I am struggling on configuring two SSIDs on a single radio interface on default VLAN. It should be a very basic setup however I can't get it to work. I don't need any security on the SSIDs and I want them both broadcasted. My AP is AIR-AP1242AG-A-K9 with 12.4 firmware. Here is my current config:
dot11 ssid test2
   authentication open
dot11 ssid test1
   authentication open
   guest-mode
interface Dot11Radio0
no ip address
no ip route-cache
ssid test1
ssid test2
However the test2 is not broadcasted... I can't put "guest-mode" under ssid test2. I got this error: "Dot11Radio0: Guest-ssid already existing on ssid test1"
I was trying to use mbssid but it requires to use VLAN, which I don't need. However if it's a must that's fine as long as both SSIDs have to be on the same VLAN.
Can anybody please provide me a sample config? Thanks!
Leo Laohoo Wed, 05/12/2010 - 18:20
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
You're almost there.
dot11 ssid test2
authentication open
mbssid guest-mode
dot11 ssid test1
authentication open
mbssid guest-mode
Don't forget to rate useful posts.  Thanks.
Difan Zhao Thu, 05/13/2010 - 09:17
Thank you for the reply! Actually I have tried the mbssid but it requires using vlans. Here is my config:
dot11 ssid test1
   authentication open
   mbssid guest-mode
dot11 ssid test2
   authentication open
   mbssid guest-mode
no ip address
no ip route-cache
ssid test1
ssid test2
mbssid
However as soon as I "no shut" the dot0 interface I got this error:
*Mar  1 16:17:28.395: %DOT11-4-NO_MBSSID_VLAN: No VLANs configured in MBSSID mode. Dot11Radio0 not started
ap#sh ip int bri d0
Interface                  IP-Address      OK? Method Status                Protocol
Dot11Radio0                unassigned      YES unset  reset                 down
How do I configure the same vlan for both SSID? Thanks!
sreejith_r Mon, 06/23/2014 - 15:06
You cannot configure two SSID's on the same vlan or without vlans.
Difan Zhao Thu, 05/13/2010 - 09:43
I just created vlan 1 as the native vlan but seems I can't assoicate two SSIDs on the same vlan... Here is the current config (some configs are omited)
dot11 ssid test1
   vlan 1
   authentication open
   mbssid guest-mode
dot11 ssid test2
   authentication open
   mbssid guest-mode
ssid test1
ssid test2
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
interface FastEthernet0.1
bridge-group 1
As soon as I try to associate test2 with vlan 1 I got this error:
Warning: Vlan 1 already mapped to SSID test1. SSIDs with same vlan association cannot be attached to the same interface.
Dot11Radio0: VLAN 1 is already mapped to SSID test1, SSID to VLAN mapping should be unique on interface.
Please help, Thanks!
