Cisco ASA Missing Attribute
Answered Question
May 12th, 2010
I'm trying to set up my ASA so our SSL VPN users can authenticate against a microsoft AD server. From what I've read I need to map the AD attribute 'msNPAllowDialin' to the Cisco Attribute 'CVPN3000−Radius−IETF−Class', but my ASA doesn't seem to have that. Is there something I'm suppose to do first for this to show up? Here's what is available:
ASA(config-ldap-attribute-map)# map-name msNPAllowDialin ?
ldap mode commands/options:
cisco-attribute-names:
  Access-Hours
  Allow-Network-Extension-Mode
  Auth-Service-Type
  Authenticated-User-Idle-Timeout
  Authorization-Required
  Authorization-Type
  Banner1
  Banner2
  Cisco-AV-Pair
  Cisco-IP-Phone-Bypass
  Cisco-LEAP-Bypass
  Client-Intercept-DHCP-Configure-Msg
  Client-Type-Version-Limiting
  Confidence-Interval
  DHCP-Network-Scope
  DN-Field
  Firewall-ACL-In
  Firewall-ACL-Out
  Group-Policy
  IE-Proxy-Bypass-Local
  IE-Proxy-Exception-List
  IE-Proxy-Method
  IE-Proxy-Server
  IETF-Radius-Class
  IETF-Radius-Filter-Id
  IETF-Radius-Framed-IP-Address
  IETF-Radius-Framed-IP-Netmask
  IETF-Radius-Idle-Timeout
  IETF-Radius-Service-Type
  IETF-Radius-Session-Timeout
  IKE-DPD-Retry-Interval
  IKE-Keep-Alives
  IPSec-Allow-Passwd-Store
  IPSec-Auth-On-Rekey
  IPSec-Authentication
  IPSec-Backup-Server-List
  IPSec-Backup-Servers
  IPSec-Client-Firewall-Filter-Name
  IPSec-Client-Firewall-Filter-Optional
  IPSec-Default-Domain
  IPSec-Extended-Auth-On-Rekey
  IPSec-IKE-Peer-ID-Check
  IPSec-IP-Compression
  IPSec-Mode-Config
  IPSec-Over-UDP
  IPSec-Over-UDP-Port
  IPSec-Required-Client-Firewall-Capability
  IPSec-Split-DNS-Names
  IPSec-Split-Tunnel-List
  IPSec-Split-Tunneling-Policy
  IPSec-Tunnel-Type
  IPSec-User-Group-Lock
  L2TP-Encryption
  L2TP-MPPC-Compression
  MS-Client-Subnet-Mask
  PFS-Required
  PPTP-Encryption
  PPTP-MPPC-Compression
  Primary-DNS
  Primary-WINS
  Privilege-Level
  Require-HW-Client-Auth
  Require-Individual-User-Auth
  Required-Client-Firewall-Description
  Required-Client-Firewall-Product-Code
  Required-Client-Firewall-Vendor-Code
  Secondary-DNS
  Secondary-WINS
  Simultaneous-Logins
  Strip-Realm
  TACACS-Authtype
  TACACS-Privilege-Level
  Tunnel-Group-Lock
  Tunneling-Protocols
  Use-Client-Address
  User-Auth-Server-Name
  User-Auth-Server-Port
  User-Auth-Server-Secret
  VPN-Smartcard-Removal-Disconnect
  WebVPN-ACL-Filters
  WebVPN-Apply-ACL-Enable
  WebVPN-Citrix-Support-Enable
  WebVPN-Content-Filter-Parameters
  WebVPN-Enable-Functions
  WebVPN-Exchange-NETBIOS-Name
  WebVPN-Exchange-Server-Address
  WebVPN-File-Access-Enable
  WebVPN-File-Server-Browsing-Enable
  WebVPN-File-Server-Entry-Enable
  WebVPN-Forwarded-Ports
  WebVPN-Homepage
  WebVPN-Macro-Substitution-Value1
  WebVPN-Macro-Substitution-Value2
  WebVPN-Port-Forwarding-Enable
  WebVPN-Port-Forwarding-Exchange-Proxy-Enable
  WebVPN-Port-Forwarding-HTTP-Proxy-Enable
  WebVPN-Port-Forwarding-Name
  WebVPN-SVC-Client-DPD
  WebVPN-SVC-Compression
  WebVPN-SVC-Enable
  WebVPN-SVC-Gateway-DPD
  WebVPN-SVC-Keep-Enable
  WebVPN-SVC-Keepalive
  WebVPN-SVC-Rekey-Method
  WebVPN-SVC-Rekey-Period
  WebVPN-SVC-Required-Enable
  WebVPN-Single-Sign-On-Server-Name
  WebVPN-URL-Entry-Enable
Correct Answer by Jatin Katyal about 6 years 10 months ago
Its not missing, it has been replaced with a different command---  IETF-Radius-Class
ldap attribute-map CISCOMAP
  map-name  msNPAllowDialin cVPN3000-IETF-Radius-Class
  map-value msNPAllowDialin FALSE NOACCESS
  map-value msNPAllowDialin TRUE ALLOWACCESS
Mapping VPN Clients to VPN Group Policies Through LDAP Configuration Example
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a008089149d.shtml#configs
Regds,
JK
Do rate hekpful posts-
Overall Rating: 5 (2 ratings)
Correct Answer
Jatin Katyal Wed, 05/12/2010 - 17:09
  • Cisco Employee,
Regds,
JK
