Cisco Catalyst 4000 Switch Console
May 12th, 2010
I have a dumb Question what type of connection is this console connection?  I thought this switch used a RJ45 + Serial so I plugged into the ethernet jack next console console not noticing its just a regular 10 base-t could this be used to console into this switch?  I have attached an image below.
Overall Rating: 1 (1 ratings)
Ganesh Hariharan Thu, 05/13/2010 - 00:11
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
A console connection is a  service that provides access to the system console of a computing device via networking technologies.
Check out the below link for console connection using PC on cisco devices.
http://www-tss.cisco.com/eservice/compass/common/tasks/task_console_port_connect.htm
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
alfredmorel23 Thu, 05/13/2010 - 15:23
I know what a console connection is; but the pic attached on my first post their it looks like a maybe 20 or 25 pin connector that says console does anyone know what the used called also I see 10-t jack beside it.
Ganesh Hariharan Fri, 05/14/2010 - 02:29
beside it.
The port shown in the picture supports DCE       DB-25 receptacle that supports a DCE EIA/TIA-232 interface.
Check out the below link hope to help !!
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008010ff7a.shtml#contermtocat4003
Ganesh.H
Jon Marshall Thu, 05/13/2010 - 16:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Edit - apologies think i may be mistaken.
What supervisor model is it ie. "sh module" on the switch.
Jon
glen.grant Thu, 06/17/2010 - 05:31
It is the ME1 interface .  Do a search on the ME1 interface and catos, too long to print here what it is used for.
