Query regarding URL in ACL for outbound HTTP
May 12th, 2010
Hi halijenn / pkampana / all
Users -> ASA -> Server (www.training.com)
I have a query for HTTP Outbound traffic .Is there is a way in ASA to allow outbound HTTP to a URL/URI instead of an IP address i.e to allow the URL / domain in the ACL.The reason being that outside server www.training,com has multiple IP Address which keeps on changing , hence the outbound ACLs object-group has to be modified accordingly to include the new IP Address every time .
I can see only 1 solution
1) Donot apply any ACL on inside interface for outbound traffic and restrict it with inspect http <L7 Policy map name> by specifying regex as www.training.com .Else i can still specify the outbound acl but on the basis of the first three octet i.e if the public ip of the server is 198.23.41.1 till 198.23.41.10 (consider that the IP addresses is always in this range) then i can specify the range 198.23.41.0/24 in the access-list destination traffic
and combine it again with inspect http <L7 Policy map name>
Please let me know if there is any other way to accomplish this.
Federico Coto F... Wed, 05/12/2010 - 19:28
  • Green, 3000 points or more
To specify access to an URL on the ASA the only way is with the regex and HTTP inspection as you mentioned.
Using an ACL only allows you to define IP addresses (which not work well for domain names as they constantly can change).
The ASA can do URL-filtering against a third-party URL filtering server but this will require another device.
If you want to do this solely on the ASA, go for the HTTP inspection policy.
Federico.
Panos Kampanakis Thu, 05/13/2010 - 09:20
  • Cisco Employee,
http://supportforums.cisco.com/docs/DOC-1268 explains how you can do what you want.
Lets assume that we want to allow only cisco.com. Here is the config snippet:
regex allowex2 "cisco\.com"
class-map type inspect http match-all allow-url-class
match not request header host regex allowex2
policy-map type inspect http allow-url-policy
parameters
class allow-url-class
  drop-connection log
policy-map global_policy
class inspection_default
service-policy global_policy global
I hope it helps.
PK
ankurs2008 Thu, 05/13/2010 - 23:55
Hi pkampana
thanks for the reply .I donot want to add new IP Address given by service provider in the object group everytime , hence as allowing URL cant be done in access-list , i have expanded the IP Address range as /24 so that i donot have to add it everytime in Outbound ACL
Please let me know if the below would be correct.
www.training.com = 198.23.41.1 , 198.23.41.7 , 198.23.41.11 , 198.23.41.16 , 192.23.41.23
access-list INSIDE permit 192.168.10.0 255.255.255.0 198.23.41.0 255.255.255.0
access-group INSIDE in interface inside
access-list TRAINING permit 192.168.10.0 255.255.255.0 198.23.41.0 255.255.255.0
class-map URLCLASS
match access-list TRAINING
regex ALLOW "training\.com"
class-map type inspect http match-all ALLOWURL
match not request header host regex ALLOW
policy-map type inspect http URLPOLICY
parameters
class ALLOWURL
  drop-connection log
policy-map MYPOLICY
class URLCLASS
service-policy MYPOLICY interface inside
Panos Kampanakis Fri, 05/14/2010 - 06:42
  • Cisco Employee,
You do not need to play with ip addresses of the url. Using just http inspection will do it
The config
  parameters
  class ALLOWURL
    drop-connection log
policy-map MYPOLICY
  class URLCLASS
will allow training.com. BE CAREFUL because it will block all other urls.
That is what you want to do?
PK
