Round robbin 'g FXO ports
May 12th, 2010
I'd like to know how to route calls through various FXO ports in a round-robbin fashion.
The default way to work is "first-available", but I have two cell-land-lines that I'd like to use in a balanced manner, because the first one is ending its minutes quickly and I have to swap them manually after a couple of weeks.
Thanks for your answers.
Overall Rating: 5 (1 ratings)
William Bell Wed, 05/12/2010 - 19:46
What signaling protocol are you using?  If using dial-peers on your voice gateway (h323 or sip) then maybe something like this:
trunk group myfxo
hunt-scheme round-robin
voice-port 0/1/0
description fxo line 1
trunk-group myfxo
voice-port 0/1/1
description fxo line 2
trunk-group myfxo
dial-peer voice pots
description offnet to whatever
trunkgroup myfxo
If you are using CUCM and MGCP, then look at Route Group configs.
Please remember to rate helpful posts.
javierfonseca Thu, 05/13/2010 - 06:35
I've tried the hunt-scheme round-robbin command, but it doesn't seems to work.
Maybe for a T1/E1 it could work (I haven't tried it), because a T1/E1 has several channels, but it looks like a FXO port is only one channel itself and it always goes from "voice-port 0/1/0 channel 1" back to "voice-port 0/1/0 channel 1" without moving to the second port.... or something like that.
Any other suggestion?
Related Content
