Cisco compatbiltiy with HP Procurve
May 12th, 2010
Hi all,
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
I would like to check if the following scenario is possible;
I have 2 x Cisco C3750G-12S-S acting as a Layer 3 Core Switch (Stacking), as well as Wireless LAN Controller for some Cisco Access Points.
However, recently there is a requirement to expand the wireless coverage, so I was thinking if HP Procurve M110 AP is compatible with Cisco C3750?
The configuration requirement is only WPA2 security and 802.1x authentication.
Difan Zhao Thu, 05/13/2010 - 11:38
I am using Cisco switches and HP APs for many clients and I don't see any problems. However I only used HP MSM series APs but never the M110 AP. Where will you enable the 802.1x? Will you enable it on Cisco 3750 core switch to authenticate the AP or enable on the AP to authenticate wireless clients? Either way you have to check the AP's spec for its capability of supporting 802.1x
