password recovery
May 12th, 2010
I have a swich with redundant sup engine and need to break the enable password of the same.
Is it required to remove the secondary sup engine from the chassis when I reload and put the primary sup engine in rommon mode?
Or will the seconfdary sup active during this process?
Richard
Ganesh Hariharan Wed, 05/12/2010 - 22:15
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Richard
Richard,
Remove secondary sup engine
proceed with password recovery for primary Sup engine onece its come up properly insert secondary sup engine for sync config,check out the below link for step by step procedure.
http://www.cisco.com/en/US/products/hw/switches/ps663/products_password_recovery09186a00800945f7.shtml
https://cisco.com/application/pdf/paws/30222/178.pdf
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
