'crypto key generate rsa' necessary for SSH?
Answered Question
May 12th, 2010
I read from the manual that the key pair will be used for SSH but just wonder does the command 'crypto key generate rsa' is necessary to enable SSH on ASA?
I can access to my firewall via SSH but when I checked in the configuration on ASA firewall by 'show run', I didn't see this command by the way. Anyone can guide me how to check if my ASA already be enabled  'crypto key generate rsa' ?
Thank you all very much for reply.
Correct Answer by Jennifer Halim about 7 years 2 weeks ago
Yes, it is necessary to generate the rsa key pair for SSH access.
Here is the command to check the keypair in your ASA:
show crypto key mypubkey rsa
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Wed, 05/12/2010 - 23:14
  • Cisco Employee,
Hope that helps.
