Qos not working on routed ports 6500. 12.1E
May 12th, 2010
Im trying to prioritize traffic matched in a class on 6500 msfc2/sup2 12.1E.  the config is as below :
policy-map VOICE_TEST
class VOIP
priority 512
class class-default
fair-queue
class VOIP
match access-group VOICE_CLASSIFY
ip access-list extended VOICE_CLASSIFY permit udp x.x.x.x x.x.x.x y.y.y.y. z.z.z.z 1025 65535
and this policy map is applied to routed interface in output direction.
int faxx/yy
ip address a.a.a.a b.b.b.b
service-policy output VOICE_TEST
when i issue the command " sh policy-map interface fa xx/yy i dont see any hits on the counters of policy map. while on the other side it is connected to router where it shows it is prioritizing the traffic.
Can you ppl see some issues in configuration for Qos. ?
TIA
Hitesh
bgandhi Thu, 05/13/2010 - 01:35
This does not mean the marking is not happening, This is probably because the processing happening at PFC. You may sniff the packets and confirm.
Bhavesh
