7604 not supporting frame-relay route
May 13th, 2010
  • Bronze, 100 points or more
Hi Pros,
I have a 7604 which I have to configure as Frame Relay Switch. I am able to configure frame-relay switching globally and set the interface as intf-type dce. But I am not able to configure any frame-relay route command under DCE interface. But I am able to execute the show command "show frame-relay route".
7604 running s72033-ipservices_wan-mz.122-18.SXF.bin. I suspected it could be a hidden command but it is not taking the command when executed.
R4-7604-P3-CORE(config-if)#frame
R4-7604-P3-CORE(config-if)#frame-relay ?
  accounting             Special accounting instruction
  broadcast-queue        Define a broadcast queue and transmit rate
  class                  Define a map class on the interface
  congestion-management  Enable Frame Relay congestion management
  de-group               Associate a DE group with a DLCI
  fast-restart           fast restart on switchover
  fragment               Enable end-to-end fragmentation for all PVCs
  ifmib-counter64        Support IF-MIB's total packet/byte counts of Counter64
                         on FR if/subif when main interface's ifSpeed < 20 Mbps
  interface-dlci         Define a DLCI on an interface/subinterface
  intf-type              Configure a FR DTE/DCE/NNI interface
  inverse-arp            Enable/disable FR inverse ARP
  ip                     Frame Relay Internet Protocol config commands
  lapf                   set LAPF parameter
  lmi-n391dte            set full status polling counter
  lmi-n392dce            LMI error threshold
  lmi-n392dte            LMI error threshold
  lmi-n393dce            set LMI monitored event count
  lmi-n393dte            set LMI monitored event count
  lmi-t392dce            set DCE polling verification timer
  lmi-type               Use CISCO-ANSI-CCITT type LMI
  local-dlci             Set source DLCI when LMI is not supported
  map                    Map a protocol address to a DLCI address
  multicast-dlci         Set DLCI of a multicast group
  policing               Enable Frame Relay policing
  priority-dlci-group    Define a priority group of DLCIs
  svc                    Enable frame relay SVCs
  traps-maximum          set max traps FR generates at link up or when getting
                         LMI Full Status message
  vc-bundle              configure a frame-relay vc-bundle
R4-7604-P3-CORE(config-if)#frame-relay route 101 inter po 4/0/0 100
% Invalid input detected at '^' marker.
R4-7604-P3-CORE(config-if)#^Z
R4-7604-P3-CORE#sh frame route
Input Intf      Input Dlci      Output Intf     Output Dlci     Status
R4-7604-P3-CORE#
Any clues.
Thanks in advance
regards,
Arun
arun kumar Thu, 05/13/2010 - 06:01
I found the reason for it. Actually there are 2 ways of configuring frame-relay route. One is to configure frame-relay route under the interface config. And the second option is to configure connect statements globally in the router. I missed noticing the second option.
thanks
Arun
