EasyVPN :crypto ipsec client ezvpn xauth
May 13th, 2010
Everytime when I reboot a easyVPN client it is prompting for username and password by prompting following command "crypto ipsec client ezvpn xauth".
How do I make connection persistent, so that it won't ask for username and password during next reboot.
I am using cisco 877 router as easyVPN server and Cisco 877 router as EasyVPN client.
My Easy VPN server configuration is  as follows cisco 877
sh run
Building configuration...
Current configuration : 2306 bytes
version 12.4
no service pad
service password-encryption
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login userauthen local
aaa authorization network groupauthor local
aaa session-id common
dot11 syslog
ip cef
ip name-server 139.130.4.4
ip name-server 203.50.2.71
ip inspect name firewall tcp
ip inspect name firewall udp
ip inspect name firewall rtsp
username cisco password 5 121A0C0411045D5679
crypto isakmp policy 3
encr 3des
authentication pre-share
group 2
crypto isakmp client configuration group vpngrp
key cisco123
save-password
crypto ipsec transform-set myset esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10
set transform-set myset
crypto map clientmap client authentication list userauthen
crypto map clientmap isakmp authorization list groupauthor
crypto map clientmap 10 ipsec-isakmp dynamic dynmap
archive
log config
  hidekeys
interface Loopback10
ip address 192.168.0.254 255.255.255.0
ip nat inside
ip virtual-reassembly
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
no ip address
ip nat inside
shutdown
interface Dialer0
mtu 1460
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname [email protected]
ppp chap password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip dns server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
ntp clock-period 17182092
ntp server 202.83.64.3
end
My cisco877 router client configuration...
sh run
Current configuration : 1919 bytes
! No configuration change since last restart
version 12.4
no service pad
hostname Goldcoast
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip cef
crypto ipsec client ezvpn ez
connect auto
group vpngrp key cisco123
mode network-extension
peer 165.228.130.43
xauth userid mode interactive
archive
log config
  hidekeys
interface Loopback0
ip address 192.168.1.254 255.255.255.0
ip nat inside
crypto ipsec client ezvpn ez inside
interface ATM0
no ip address
pvc 8/35
interface Vlan1
no ip address
ip nat inside
shutdown
interface Dialer0
mtu 1460
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp chap password
no ip http server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
login
ntp clock-period 17182119
end
I am able to connect. But I want to make the connection dynamic rather than user interactive. Please help me.
Siva.
Federico Coto F... Thu, 05/13/2010 - 11:35
  • Green, 3000 points or more
Have you tried on the client to specify the user?
     username password
Federico.
sivakumar_ks Thu, 05/13/2010 - 15:00
I tried that , but still it came up manual xauth at set at server end. But I can't find any option at EasyVPN server related to manual or dynamic.
Siva.
Federico Coto F... Thu, 05/13/2010 - 16:05
The ''save-password'' command on the server should allow the remote client to save the XAUTH password.
If you issue the command:
''no xauth userid mode interactive''
On the client, does it ask for user credentials?
Federico.
sivakumar_ks Fri, 05/14/2010 - 05:48
Sorry for the late reply.
I am getting following error after removing xauth. Here is the error.
ay 14 12:43:47.020: EZVPN(ez) Server does not allow save password option,
enter your username and password manually
May 14 12:43:47.020: EZVPN(ez): *** Logic Error ***
May 14 12:43:47.020: EZVPN(ez): Current State: READY
May 14 12:43:47.020: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:47.020: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:47.020: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr=Server_public_addr=
May 14 12:43:49.272: EZVPN(ez) Server does not allow save password option,
May 14 12:43:49.272: EZVPN(ez): *** Logic Error ***
May 14 12:43:49.272: EZVPN(ez): Current State: READY
May 14 12:43:49.272: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:49.272: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:49.272: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr=Server_public_addr=
May 14 12:43:51.620: EZVPN(ez) Server does not allow save password option,
May 14 12:43:51.620: EZVPN(ez): *** Logic Error ***
May 14 12:43:51.620: EZVPN(ez): Current State: READY
May 14 12:43:51.620: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:51.620: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:51.624: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr=Server_public_addr=
May 14 12:43:53.701: EZVPN(ez) Server does not allow save password option,
May 14 12:43:53.701: EZVPN(ez): *** Logic Error ***
May 14 12:43:53.701: EZVPN(ez): Current State: READY
May 14 12:43:53.701: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:53.701: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:53.701: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr= Server_public_addr=
May 14 12:43:55.989: EZVPN(ez) Server does not allow save password option,
May 14 12:43:55.989: EZVPN(ez): *** Logic Error ***
May 14 12:43:55.989: EZVPN(ez): Current State: READY
May 14 12:43:55.989: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:55.989: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:55.989: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr=Server_public_addr=
Goldcoast(config-crypto-ezvpn)#
May 14 12:43:58.009: EZVPN(ez) Server does not allow save password option,
May 14 12:43:58.009: EZVPN(ez): *** Logic Error ***
May 14 12:43:58.009: EZVPN(ez): Current State: READY
May 14 12:43:58.009: EZVPN(ez): Event: MODE_CONFIG_REPLY
May 14 12:43:58.009: EZVPN(ez): Resetting the EZVPN state machine to recover
May 14 12:43:58.009: %CRYPTO-6-EZVPN_CONNECTION_DOWN: (Client)  User=  Group=vpngrp  Client_public_addr=Server_public_addr=
siva.
Federico Coto F... Fri, 05/14/2010 - 07:44
Ok,
Add again the commands you have originally.
Question:
When you do a:
show crypto ipsec client ezvpn
on the client, does it say:
Save Password: Allowed
It could also be a software version issue. This would depend on which release this feature was introduced.
Please add this command:
crypto map clientmap client configuration address respond
Test again.
Federico.
sivakumar_ks Sat, 05/15/2010 - 05:12
output
Inside interface list: Loopback0
Outside interface: Dialer0
Current State: XAUTH_REQ
Last Event: XAUTH_REQUEST
Save Password: Disallowed
Current EzVPN Peer:
I tried this command
crypto map clientmap client configuration address respond at client side and still no luck.
siva.
Federico Coto F... Sat, 05/15/2010 - 13:43
You're getting:
That's why it keeps prompting for password everytime.
What's your IOS version?
Would you be able to upgrade if necessary?
Federico.
sambikar1s Wed, 03/05/2014 - 07:16
Hi Federico,
I have the same issue where my ezvpn gets reset. Can anyone please help?
I have the following information.
1. My IOS is c2900-universalk9-mz.SPA.151-4.M4.bin.
2. My configuration under EzVPN is:
crypto ipsec client ezvpn vpnclient
connect auto
group *********** key ************
peer ********
acl 102
username ****** password **********
xauth userid mode local
3. Router#  show crypto ipsec client ezvpn
Easy VPN Remote Phase: 8
Tunnel name : vpnclient
Inside interface list: GigabitEthernet0/2, GigabitEthernet1/0
Outside interface: GigabitEthernet0/0
Current State: IPSEC_ACTIVE
Last Event: MTU_CHANGED
The issue:  Keep getting the same error:
Mar  4 22:38:13.706: EZVPN(vpnclient): *** Logic Error ***
Mar  4 22:38:13.706: EZVPN(vpnclient): Current State: CONNECT_REQUIRED
Mar  4 22:38:13.706: EZVPN(vpnclient): Event: XAUTH_STATUS
Mar  4 22:38:13.706: EZVPN(vpnclient): Resetting the EZVPN state machine to recover
