ASA/PIX not responding to Pings from Outside interface
Answered Question
May 13th, 2010
                       I need a ASA/PIX firewall to respond to my ping eneting the outside interface from a specific subnet. Is this ACL correctly written to do that?
                       access-list 101 permit icmp 76.X.X.X 255.255.255.192 any echo-reply
                       access-group 101 in interface outside
Correct Answer by Jon Marshall about 6 years 8 months ago
iketurner931 wrote:
               Thanks Jon,
                                 Are you saying that the Pix by default will not respond to pings but the ASA will?
No, the pix should respond by default to pings as well.
Jon
An acl allows ping through the firewall not to the firewall.
You need this instead -
icmp permit 76.x.x.x 255.255.255.192 echo-reply outside
however by default an ASA should respond to ping on it's interfaces anyway so you need to check your config.
Note also that you cannot ping across the ASA to an interface so if you are outside you can ping the outside interface but not any of the others.
Jon
Overall Rating: 5 (2 ratings)
Correct Answer
Jon Marshall Thu, 05/13/2010 - 06:45
Jon
Charlie Mayes Thu, 05/13/2010 - 06:59
               Thanks Jon,
Correct Answer
Jon Marshall Thu, 05/13/2010 - 07:08
iketurner931 wrote:
               Thanks Jon,
Jon
