VLANs On WAN Side
May 13th, 2010
I'm looking for a security device that can handle VLANs on the WAN side.
Like virtual WAN interfaces; one for each VLAN
I'm hoping something like the SA540 can do it.
Any suggestions?
rshao Mon, 05/17/2010 - 17:44
SA500 today supports only vlan on LAN ports.  vlan/sub-interfaces over WAN is not supported.
You may want to check out Cisco IOS 800 router or ASA that should support what you are looking for.
On the other hand, I am interested in understanding what you are trying to accomplish with subinterface support over WAN?
i.e. sub-interface based application service provided by local ISP? or?  Feel free to send me through private message if preferred.
Richard
FratianiD Mon, 05/17/2010 - 17:59
Could this be placed on the roadmap for the SA540?
It would really make this device top shelf.
I would use this to consolidate my WAN links (I currently have four).
I want to send all the WAN links to different VLANs on a switch and have one or two Trunks out of the switch to the SA540 WAN(s).
This would allow me to have more than two WAN links.
