Locale change on 6941 at CUCM 7.1(5) fails
May 13th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normale Tabelle"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I've got a 2-node CUCM cluster running 7.1(5) and some 6941 phone with firmware release 9.0.2. The phones should speak Japanese, German and Dutch by choice.
I've installed those locale-packages:
cm-locale-combined_network-7.1.5.1000-1.cop.sgn
cm-locale-nl_NL-7.1.5.1000-1.cop.sgn
cm-locale-ja_JP-7.1.5.1000-1.cop.sgn
cm-locale-de_DE-7.1.5.1000-1.cop.sgn
and those found als "endpoint locale installer" in the 6941 download-section at CCO:
po-locale-ja_JP-9.0.1.1000-1.cop.sgn (not available as 9.0.1)
po-locale-nl_NL-9.0.2.1000-1.cop.sgn
po-locale-de_DE-9.0.2.1000-1.cop.sgn
I installed all those packages on both servers and rebootet the cluster several times since this installation.
If I change the locale on a phone, the announcements are in the right language, but the phone menus stay english.
The EM-service seems to be in the right language, but if I try it in japanese, there are only small boxes instead of characters- it seems like the symbol set is missing.
If I sniff the phone's traffic using wireshark during the boot, I see that the fil rtl-sccp.jar from the appropriate language-folder is requested and as it looks also delivered. If I download such a file to my PC and unzip it, it contains right-looking resource files.
I've seen FW 9.0.2SR1 on CCO, but found nothing about this issue in the release notes.
Is there anybody with a similar problem who has found a solution?
Best Regards
Jörg
camilosanz Thu, 09/30/2010 - 00:42
Any updates on this case? I'm having same problems here trying to set the user locale in spanish. )-:
Marcel Tempelman Wed, 10/27/2010 - 03:20
I have the same problem but then on UCME 8.1 with the Dutch language. I've another 8.0 installation with the same issue. A 7931 gets nice dutch softkey options but the 6941 stays in English.
Marcel.
camilosanz Wed, 10/27/2010 - 04:09
I have opened a TAC with Cisco and here is the response:
-       Unfortunately localization will not be available on CME for 69XX phones until CME 8.6
-       CME 8.6 will be released till March 2011
-       You can contact Cisco after March 2011 for Spanish locale on 69XX phones
So, we will wait until March 2011.
Camilo
Ales Kunc Mon, 02/21/2011 - 08:46
Hi everyone,
I've encountered the same issue on CUCM 7.1.5-10000-12
I installed "po-locale-sl_SI-9.0.2.1000-1.cop.sgn", rebooted CM & TFTP services and nothing happend, phones remain in english language.
I also rebooted both servers, but no luck.
Did enyone get any news on this matter?
Kind regards!
Ales
Related Content
