CatOS to Cisco IOS Software
Hi All
Hopefully somebody will be able to help on this issue I am seeing, I am trying to convert a sup2 running CatOS to IOS using the following link:
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml#conv_msfc_2
All goes well up to step 15 where I am loading the IOS software but this is where it fails....please see below.
Download Completed! Booting the image.
Self decompressing the image :
#################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) c6sup2_rp Software (c6sup2_rp-JK9SV-M), Version 12.2(18)SXD7b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 08-Dec-06 10:34 by ccai
Image text-base: 0x4002100C, data-base: 0x425D0000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
----------------THIS IS WHERE THE SYSTEM HANGS-----------------------------------------------------------------
I get no output after I see the last line in the above output ([email protected].) as the system is in a Lab and I am remote using the console port, when I go to the lab all lights are off on the Supervisor....
I have attached a print screen of the commands on the Supervisor, I have tried a different IOS and flash card, I have also replaced the MSFC2 on the Supervisor.
Many Thanks MJ
robert.horrigan Thu, 05/13/2010 - 11:38
Try reformatting the flashcard, or better yet, use a flash card from a working SUP that's running this image.
craig bache Sat, 05/15/2010 - 00:00
I thnk there was some kind of memory issue on the card as this is only fail when putting the IOS in to the DRAM.
Related Content
