Cisco 2821 Drops LAN Connection
frivers
I have a Cisco 2821 with a Etherswitch WIC connected to an ISP router and a network switch and for a couple of days now the WIC dropped it's connection to the LAN.  Reloading the router solves the issue until the next day.  I checked the logging on the router and nothing.  I was able to ping the virtual interface on the router while directly connected via the console.  All virtual and physical interfaces were up.  However, I wasn't able to ping anything on the local network.  There were no crash logs on the server.  How can I troubleshoot this issue?
The only explanation I had is that I had the WIC interface connected to a gigabit port.  Would that cause problems--connecting a 10/100 WIC to a Gigabit port on another switch???
On the interface in question, it is running half duplex which is why you are seeing the collisions you will need to correct this and you collisions should go away. make sure both ends are setup the same way as this could also be a duplex mismatch.
Mike
14 Replies 14
frivers
Here's the show interfaces.  What concerns me are the collisions and interface resets.
ABT_OPS#show interfaces
FastEthernet0/3/0 is up, line protocol is up
  Hardware is Fast Ethernet, address is 001b.54f0.4d29 (bia 001b.54f0.4d29)
  Description: TRUNK_PORT
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 252/255, txload 3/255, rxload 4/255
  Keepalive set (10 sec)
  Half-duplex, 100Mb/s
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 1926000 bits/sec, 426 packets/sec
  5 minute output rate 1244000 bits/sec, 424 packets/sec
     1155584 packets input, 586968670 bytes, 0 no buffer
     Received 44 broadcasts, 0 runts, 0 giants, 0 throttles
     1181325 packets output, 412154404 bytes, 0 underruns
     34516 output errors, 45158 collisions, 2 interface resets
     0 unknown protocol drops
     0 babbles, 13640 late collision, 15048 deferred
     0 lost carrier, 0 no carrier
FastEthernet0/3/1 is up, line protocol is up
  Hardware is Fast Ethernet, address is 001b.54f0.4d2a (bia 001b.54f0.4d2a)
  Description: TO_FIREWALL_UNTRUSTED
     reliability 255/255, txload 2/255, rxload 1/255
  Full-duplex, 100Mb/s
  Last input never, output never, output hang never
  5 minute input rate 432000 bits/sec, 155 packets/sec
  5 minute output rate 1069000 bits/sec, 155 packets/sec
     393156 packets input, 135668499 bytes, 0 no buffer
     Received 68 broadcasts, 0 runts, 0 giants, 0 throttles
     368804 packets output, 271710924 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
FastEthernet0/3/2 is up, line protocol is up
  Hardware is Fast Ethernet, address is 001b.54f0.4d2b (bia 001b.54f0.4d2b)
  Description: TO_LAN_TRUSTED
     reliability 255/255, txload 2/255, rxload 2/255
  5 minute input rate 883000 bits/sec, 291 packets/sec
  5 minute output rate 868000 bits/sec, 295 packets/sec
     834454 packets input, 292393570 bytes, 0 no buffer
     Received 1355 broadcasts, 0 runts, 0 giants, 0 throttles
     823484 packets output, 320229130 bytes, 0 underruns
Mike
I suspected this and called my ISP since I have no control over their router.
What is the confiruration of the interface on your side?
Auto/Auto
or
Hard set speed and duplex?
Mike
I didn't configure the speed, so I assume it's auto.  I did however configure it as spanning-tree portfast.
Just confirmed that ISP is having collisions and CRCs on their end as well.
My guess is that is your side is set to Auto is that thier side is set to 100/full which will cause a duplex mismatch.
Mike
Is the affected interface FastEthernet0/3/0? It's using half duplex with output errors & collision!!!
Francisco
Have you tried hard coding duplex on both sides?
Actually this is 10g port, cannot change speed/duplex.  I don't see input errors.
#show arp
Protocol  Address          Age (min)  Hardware Addr   Type        Interface
Internet  1.1.1.1                 -   0005.dd32.6000  ARPA        GigabitEthernet0/0
Internet  1.1.1.2                45   0005.5f1e.68cc  ARPA        GigabitEthernet0/0
#show cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater
Device ID            Local Intrfce         Holdtme   Capability    Platform   Port ID
xxxxxx                    Gig 0/0               147            R        12410/PRP Gig 2/0
#show int g0/0
GigabitEthernet0/0 is up, line protocol is up
  Hardware is GigMac 1 Port 10 GigabitEthernet Plus, address is 0005.dd32.6000 (bia 0005.dd32.6000)
  Internet address is 1.1.1.1/30
  MTU 4470 bytes, BW 10000000 Kbit, DLY 10 usec, rely 255/255, load 1/255
  Full Duplex, 10000Mbps, link type is force-up, media type is LR 1310nm
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     29 packets input, 11339 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 29 multicast, 0 pause input
     233 packets output, 34595 bytes, 0 underruns
     Transmitted 0 broadcasts
     0 lost carrier, 0 no carrier, 0 pause output
sorry , reply to wrong thread. I am new.
What confuses me is that I also lose connection on the LAN side. Will do "speed 100" "duplex full" on it tonight.
After modifying the speed settings, the errors were still there.  The ISP was getting CRCs on their end of the connection though and so we ended up changing the cable which eliminated the errors.  Hopefully this solves the connection drop issue.
