IP Communicator kills Anyconnect VPN Connection
Answered Question
May 13th, 2010
  • Green, 3000 points or more
Anyconnect version 2.5.0217
ASA 8.0.5
IP Communicator 2.1.4
Connecting with Anyconnect and can access myremote network ok. If I launch IP Communicator it fails to register and my remote access via Anyconnect stops working. I need to close IP Communicator and restart Anyconnect to get my connection back. IP Communicator works just fine with the ipsec client. Any ideas?
Correct Answer by JORGE RODRIGUEZ about 6 years 11 months ago
Hi Adam, long time friend !!
Sounds like bug,  I did the search in database. this one resambles the behaviour..
Bug ID: CSCte42788
ASA anyconnect DTLS CONN is torn down when tftp error MSG is rvd- CIPC
Symptom:
ASA with anyconnect DTLS connection, when tftp
inspection is enabled, if a TFTP file transfer is attempted
from the anyconnect client and if the file is not
found (or results in any TFTP error message returned), it
will intermittently disconnect the DTLS session also.
This will cause a temporary stoppage of traffic flow
as anyconnect client re-establishes the connection.
This is commonly seen in Cisco IP communicator when it tries to use
TFTP and the file is not on the TFTP server (call manager).
Conditions:
1) TFTP from client and results in a TFTP error message
2) TFTP inspection is enabled
Workaround:
1)Disable TFTP inspection
2) Use TLS intead of DTLS
Best Regards
Jorge
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Thu, 05/13/2010 - 15:04
Bug ID: CSCte42788
Symptom:
Conditions:
Workaround:
Best Regards
Jorge
acomiskey Fri, 05/14/2010 - 05:54
Thanks Jorge, haven't been around for a while, nice to see you guys haven't lost your touch!
Disabling tftp inspection on the ASA did the trick!
