Routing failed to locate next hop for icmp from NP Identity
May 13th, 2010
Iam configuring Site to Site tunnel between ASA 5505.
My topology:   10.77.59.0 ==Lan==|ASA1|=========|ASA2|==192.168.1.0
  and  One more tunnel bw
192.168.1.0==|ASA2|=====|Draytek|==192.168.16.0
  Both the tunnel is up any from inside PC i can ping any PC in both the ASA and Draytek  network
  From ASA2 iam not able to ping any Lan ips (even when source interface specifed)
ie,  From ASA1 i can ping 192.168.1.1(inside interface of ASA2) and i got reply
From Draytek i can ping any lan ip and iam getting reply
From ASA2 i can't ping 10.77.59.9(inside interface of ASA1) or other Tunnel to Draytek (Lan ip 192.168.16.1)
when i check the log it shows the error:
  6     May 13 2010     08:04:14     110003     192.168.1.1     0     0     192.168.16.1     Routing failed to locate next hop for icmp from NP Identity Ifc:192.168.1.1/0 to inside:192.168.16.1/0
It seems like routing issue but iam not able to understand
This is my Config:for routing
ASA01# sh asp table routing  in   255.255.255.255 255.255.255.255 identity
in   127.0.0.1       255.255.255.255 identity
in   10.77.59.9      255.255.255.255 identity
in   WAN ip  255.255.255.255 identity
in   WAN ip  255.255.255.240 outside
in   10.77.59.0      255.255.255.192 inside
in   192.168.1.0 255.255.255.0   outside
in   0.0.0.0         0.0.0.0         outside
out  255.255.255.255 255.255.255.255 outside
out  WAN ip  255.255.255.240 outside
out  192.168.1.0 255.255.255.0   via 192.168.1.1, outside
out  224.0.0.0       240.0.0.0       outside
out  0.0.0.0         0.0.0.0         via WAN ip, outside
out  255.255.255.255 255.255.255.255 inside
out  10.77.59.0      255.255.255.192 inside
out  224.0.0.0       240.0.0.0       inside
out  255.255.255.255 255.255.255.255 _internal_loopback
out  224.0.0.0       240.0.0.0       _internal_loopback
out  0.0.0.0         0.0.0.0         via 0.0.0.0, identity
out  ::              ::              via 0.0.0.0, identity
Gateway of last resort is WAN ip to network 0.0.0.0
Sh ip route:
C    10.77.59.0 255.255.255.192 is directly connected, inside
C    123.238.10.144 255.255.255.240 is directly connected, outside
S    192.168.1.0 255.255.255.0 [1/0] via 192.168.1.1, outside
S*   0.0.0.0 0.0.0.0 [1/0] via WAN ip, outside
ciscoasa2# sh asp table routing
in   192.168.1.1     255.255.255.255 identity
in   WAN ip   255.255.255.248 outside
in   10.77.59.0           255.255.255.192 outside
in   192.168.1.0     255.255.255.0   inside
in   Draytek         255.255.255.0   outside
out  WAN ip   255.255.255.248 outside
out  10.77.59.0           255.255.255.192 via 10.77.59.9, outside
out  Draytek         255.255.255.0   via 192.168.16.1, outside
out  192.168.1.0     255.255.255.0   inside
  Any help please
Jennifer Halim Fri, 05/14/2010 - 01:53
Can you share configuration on both ASA?
Also, pls make sure that you have "management-access inside" on ASA1, and also "inspect icmp" on both ASA1 and ASA2.
patdurante Fri, 11/18/2011 - 06:41
Man, you just helped me resolve a 3 day issue with a site to site VPN.  Thanks for the tip about management-access inside.
