Conference problems
May 13th, 2010
Hello Every one I had Problems with conference in call manager version 7.0.2.20000-5   The issue here whe i make a call from one remote site to another and in the las site the person who receives the call make the conference, the first call is droped, this phone shows not enough bandwidth.
The location betwen sites has codec g.729 and locally g.711 could this can impact the conferences?
Thank you for your help.
Jaime Valencia Thu, 05/13/2010 - 17:29
  • Cisco Employee,
  • Hall of Fame,
    2011
If you're using the SW CFB then you can only use G711. if you want to keep using G729 with SW CFB you need XCODER, or to use a HW CFB.
Depending on your configuration you might also have not allocated the necessary BW based on that "not enough BW" message, look at your location configurations and make sure enough BW is available.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
