DHCP passthrough not working in in-band mode
Answered Question
May 13th, 2010
Hi Faisal,
wireless client is not getting ip address from dhcp server via CAS server,
here is the scenario,
1. inband cas network configuration:
Trusted Interface (to protected network)Untrusted Interface (to managed network)
IP Address
Subnet Mask
Default Gateway
Set management VLAN ID:
Pass through VLAN ID to managed network
IP Address
Subnet Mask
Default Gateway
Pass through VLAN ID to protected network
2. wireless clients are in untrusted vlan which is 104 and I've mapped the 104 vlan to 400 (trusted vlan)
untrusted vlan                                          trusted vlan
140                                                        400
3. Managed subent
ip subent        vlan
10.161.136.5 / 255.255.248.0                                                140
10.161.136.5 is ip subnet for trusted vlan 400
4. ARP entry is not configured
in switch, untrusted and trusted ports are configured as trunk port and allowed untrusted and trusted vlans respectively.
when we move wireless client into vlan 400 manually its getting ip address but when wireless client is in vlan 140 its not getting ip address and in switch configuration both trusted and untrusted ports are trunk port and using native vlan is 1
from WLC to switch port is also trunk port and allowed for all vlans
do I need to configure ARP entries or what other configurations are needed to work CAS as a DHCP passthrough.
Thank you
Correct Answer by Faisal Sehbai about 6 years 9 months ago
Laxman,
Three things:
- If it's in VGW, trusted and untrusted interfaces must have same IP address
- Uncheck the "pass through VLAN" on both sides
- Move away from VLAN 1 if possible!
HTH,
Faisal
Overall Rating: 5 (1 ratings)
Correct Answer
Faisal Sehbai Fri, 05/14/2010 - 12:31
Laxman,
Three things:
HTH,
Faisal
blaxucisco Mon, 05/17/2010 - 01:31
Hi Faisal,
Thank you for your answer. DHCP passthrough is now working without changing anything in CAS. Some vlan configuration wasn't in switch so that I got the problem. we have configuration of CAS is in HA mode in HSRP environment. and current configuration which I have posted here is working smoothly. I want to know the impact of corrent configuration (different ip address of trusted interface and untrusted interface, passthrough VLAN ID to managed network is checked).
now I need to configure ADsso. can you please check the ktpass command and suggest me it is correct or not?
environment is here..
Number of DCs              =  3
OS of DCs                    =   windows 2008 standard (SP2)
AD domain functionality  =    Mixed mode with 2003
Domain name                = laxman.com
Domain user name        = ssouser
Command is here
ktpass –princ [email protected] -mapuser ssouser -pass password123 -out c:\output.keytab –ptype KRB5_NT_PRINCIPAL
+DesOnly
Thank you
