1522 AC Power Connector Question
May 13th, 2010
Hi all,
I'm facing the following doubt regarding the AC Power Connector on the 1522 AP.
We are powering up the AP through PoE, so the AC Power Connector is not used.BUT,do i have to seal/protect the connector or leave it as is?
Anyone facing the following doubt?
Thank you all
George Venianakis Tue, 01/04/2011 - 01:38
Hi Panayiotis
You definitely need to cover the plug. Reading from http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps8368/product_data_sheet0900aecd8066a157.html
When AC power is not used (for example, when you use PoE or 12 VDC to power the access point), you should cover the unused connector. A cover is available from Remke (see http://www.remke.com for part number 75-0086).
A little late reply but I hope this could come handy for others having the same problems.
Cheers
kyle woodhouse Tue, 12/11/2012 - 10:50
I ran into this issue as well.  The best part is that Remke.com has a minimum order requirement.
"Minimum order amount is:        $100.00"
Its pretty frustrating that the AIR-CAP1552 units come with lots of accessores like a grounding lug and COAX-SEAL compound to weather proof the unit but it doesnt come with a power cover!  Its crazy considering how many people will power these units with PoE these days.
Just for refrence my unit was an AIR-CAP1552E-A-K9 so it looks like this is an issue with the 1520 and 1550 units.  Definantly something to watch out for when ordering these.
Also for refrence, it may seam trivial but when you see the power connector you will get it.  Its number "1" in the picture below.  Cover must be ordered seperatly!!
Vinay Sharma Sun, 05/29/2011 - 07:05
  • Gold, 750 points or more
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
dkalinsky Wed, 01/15/2014 - 04:31
I've got this information from 1550 ordering guide http://www.cisco.com/en/US/prod/collateral/wireless/ps5679/ps11451/data_sheet_c78-719520.html
"When AC power is not used (for example, when you  use PoE or 12 VDC to power the access point), you should cover the  unused connector. A cover is included with the power injector and is  also available from Remke (visit http://www.remke.com and search for part number 75-0086)."
So, this cover is included with AIR-PWRINJ1500-2=.
Kalinsky Dm.
Scott Fella Wed, 01/15/2014 - 05:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
The MESH AP's come with these covers already. If you misplace them, then you can purchase replacements from that company mentioned.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
